Has anyone had experience with the Hex Trap bar?
Looks like it could be a bit easier/safer on the back.
I'm not about to buy one, just a random discussion topic more than anything.
Part of me thinks that it'd allow you to lift more without risking the back, but at the same time makes me think that if the back is supposed to be getting a workout during DLs then you're kind of cheating.
I'm thinking it makes the squat a pull exercise rather than push too.
http://www.t-nation.com/free_online_article/most.../the_trap_bar_deadlift
Edited by ActionDan
Looks like it just targets your legs and traps more due to being able to load more weight onto the bar and retain a more upright/vertical spine.
You're right, somewhat defeating the purpose....though I'd definitely give it a shot myself right now - surely better than not doing deadlifts at all :P
Yes you will, I'm pretty sure your post count will start going backwards now too.
Until you go and squat again.
And don't hate on vagina's a decent one can take an absolute pounding.
Edited by ActionDan
I didn't squat last night when I was supposed to, will I lose all my gains?
If you don't mind contracting superaids and head cancer, you have nothing to worry about.
People keep referring to vaginas in a derogatory sense, implying weakness.
It's been said before, that testicles are pretty damn fragile, but the vagina can take a pounding by comparison.
Take that how you will :D
Edited by ActionDan
It's been said before, that testicles are pretty damn fragile, but we vagina can take a pounding by comparison.
Vaginas ftw.
Exactly. Doing this exercise to avoid an injury that never used to be there is defeating the purpose of building the back stronger.
Stronger back = deadlift more.
Working the rest of the muscle around the problem makes those muscles stronger, but not the injured ones = imbalances
Imbalances are right up my alley, I should definitely get one.
Just gettig freight quotes on racks at the moment.
What?
I'm saying deadlift the proper way after, in this case back, is healed.. Not do something that is a way around fixing the issue.
thoughts about tough mudder?
http://toughmudder.com.au/
was thinking about doing some training for it in september so bit of time to get 'fit'
Hit the uphill cardio with a weighted backpack and run through water.
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
