Yeah gonna suffer DOMS hard, but should be worth it. If I find the load too taxing I'll cut down. I just wanna exercise as much as I can to make up for lack of upper body movements. Need to keep the calories off.
I don't think you need to worry about this, especially next week.
If you injured yourself badly I'd be reluctant to lean on it without at least giving it a weeks rest.
Better yet, see your chosen therapist and see what they say.
Seems like you're busy enough squatting anyway :)
Tried an empty bench bar in the same session and it didn't present any pain...I could be back to upper body sooner than I thought :)
Playing it safe though. Do we think it's worth doing movements like bench with an empty bar for rehab? Or just wait until completely healed and get back into the weights?
Feeling pain or not, isn't a good indicator with the rotator for recovery. The pain is there when the swelling goes up and that can take a few minutes to an hour before you start hurting. Hence your bench blew it out but, you didn't feel it till later on a relatively light excersise. You can have deterioration in the muscle without feeling it as pain, so be carefull.
testing very carefully the 'weakness' is the way to go. You want the strength to be at least that of the unijured side.
Bench press isn't a rehab movement for this injury. Don't bother with it. Even the empty bar bench doesn't address anything related and you just look like a feeb doing it.
Copy/paste from my build thread as questions get answered quicker in here.
For some reason, my back is worse than it's been so I either did something Friday night or sleeping in shit hospital chairs/not sleeping is giving me grief (Kate has been in pre-labour for the last 3 days so we've been in and out and not sleeping very much). No gym on Monday as a result so I've had a good 3-4 days off.
Not even a stretch is helping me and it's pinching randomly when I'm not doing much.
I've noticed, with squats, that if I go below parallel my body tends to lean forward at the bottom of the motion which I'm wondering if that's causing some kind of cantilever effect on my lower back as I come back up. Or is some form of forward tilt at the bottom of the motion normal/acceptable?
Extra info: A podiatrist friend came over on sunday and did some tests, said my legs are 1.5cm different lengths, specifically from the waist down so nothing from the back as she measured that too. I put orthotics back in my shoes (just off the shelf ones) on her advice on Sunday but I "think" my back was already playing up before that.
Edited by ActionDan
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
