$10 per kg pretty much. Though as you can see diff protein contents - my point being, realistically if I'm going to see any difference from the lower protein amount given my workload. I'm guessing not.
Ayo if you don't care about mixability and lactose, go the concentrate. Personally I can't stand unmixed shit, so I like the isolate. I also have a slight aversion to too much lactose.
Okay, well that will certainly mix easier than the concentrate...but meh...get a sample or a 1kg bag of the concentrate and see what it's like?
I go through this stuff fairly quickly, so even a 5kg bag of a bad flavour or something doesn't phase me.
I find concentrate mixes fine, have had a few brands no clumps. Just don't be lazy and only shake it 3 times.
Edited by Mangune
Either way (including calcium cassinate), easiest way to mix is with a stick blender in a tall cup , I do oats plus frozen blue berries as my breakfast with some non flavoured pure protien. Simple clean up and ready in seconds.
Concentrate is slightly slower to digest vs isolate (both are rapidly absorbed however , so work as post workout pretty well). If you don't care about taste ,Concentrate is the way to go.
ive gone off pretty much all supplements. Only the occasional pre workout if i am real run down after work.
otherwise its just food food food for me. Getting pretty tired of eating chicken, fish and steak though...
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
