There wasn't initially, I'd say Birds edited his post before TTT finished quoting it.
Although: it doesn't say edited so perhaps TTT and I just misread it the first time (the case for me) or give no ducks for numerical accuracy? (the case for TTT?)
Edited by ActionDan
Here's a random question.
Kate mentioned that during and after exercise she gets vary tight muscles, so much so in the shoulders that she will get a headache if she has used her shoulders.
She gets the same thing in her legs but it's less problematic there.
She's had this since her teens so its not pregnancy related and she stretches plenty and is far more flexible than me, and I can touch my toes easily enough.
Thoughts?
She's anything but soft when it comes to pain.
Posterior baby delivered completely drug free is testament to that...
I'm talking too much tension in the muscles how to fix/avoid.
Thanks for the suggestion TTT, I should have specified genuinley useful suggestions :)
Ah well there's your problem right there. Deadlifts fix life in general.
Know someone with abdominal split like that, can't do too much with it. Might have to look at surgery.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
