Cuban press f**ked my other shoulder.
stuck to doing band rotator stuff along with overhead press which doesn't hurt and actually feels like it has helped some.
Anyway, I don't really care about it much anymore.
No 200 squat because girlyman.
knew it
I'm back squatting!... with a kettlebell:(
did a bunch of goblet squats, and lunges... almost died
might try squatting the bar today... injuries are boring and gay but at least I get lots of bench practice in... programmed for 150kg for next comp in Sept
don't know how much longer I'll be in the 90kg class for though... put muscle on and got heavier while not deadlifting or squatting... did bench only at Nats and accidentally weighed in at 90.6kg... didn't do any form of weight cut though... except for not eating breakfast or drinking any water in the morning... benched 140kg... missed 145kg about halfway up
Nick, your next comp is the GPC Big Bench on Sunday the 4th of August at PTC Powerlifting
Its a bench only event, raw and equipped, National single lift records can be broken
I have around 20 so far entered, this will be huge
I doubt it. If you weren't doing heavy ones. If you got the pain while doing them it was likely from something earlier (rotator injury has a delayed onset). If you have completely rooted rotator cuff you can't complete the movement usually.
Thats fine. You don't want to overtrain. Bands or Cuban press. Overhead press is bad for your injury, stop doing it, till you have cuban press abillity. The rotator issues are refered pain. You might be able to complete the movement but, inflamation onset takes time.
Then you wont bench press for a while? I think that comment is that of bench press addict in denial...ha ha.
Whaaaaat !
Because need squat more!
Does anyone have a good vid of a bent row, I video'd myself last night sand want to compare how far over others are bending.
I dropped off some weight to play with angle and can bend over further when it's lighter of course but can't, maintain that as the sets get heavier.
In my vid I would say I'm getting around 45 degrees.
I see a lot of vids of people horizontal, but I thought that was a pendlay row?
New toy arrived, looking forward to trying this out as I've maxed out my tracksuit pants and jacket pockets.
Also went to the physio, may need to go under the knife again (not as bad as it sounds and explains why I've been tender), won't clog this thread up though, details in my build thread.
might be a repost, but I found this to be an interesting read...
http://ausbb.com/bulk-nutrients/23192-good-bad-ugly-must-read-if-you-buy-wpi-wpc.html
oooooooooooo shiiiiiiiiiiiit lol. f**k the attitude of some of those guys pisses me off. They've obviously been buying the dodgy shit for too long and are really quite upset to discover how much they've been ripped off - so much so that they're defending the company in the hopes they can convince everyone reading as well as themselves that the results were bogus.
BN4LYF!
Whats wrong with steak, chicken,fish and eggs ?
I find it amusing that you "healthy" guys try not to buy any packaged carbs or fats, preferring to buy fresh, but dont think twice about buying manufactured pre packed protein
If the Russians are doing it, we probably should too - steak and potatoes
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
