Flexibility and squat depth is irrelevant.
Max cant touch his toes, squats deeper than anyone here
Its mobility you should be looking at
No one here stretches, but most do mobility exercises, although Max and Martin don't.
What they do do is perform every rep of every set to its correct range of motion, even warm ups with empty bars
Just food for thought
Dan does, he is very tight in the hips, yet can kick over anyones head (2 x World Kickboxing Champ). Very flexible, yet lacks mobility in the hips.
Mobility World seems to be the best site for that stuff, has some very good information on there
had to squat on the smith machine last night, found i could go much much lower then when I do with the bar by itself. Probably another 2 inches. Not sure why, I wasn't leaning back into the squat and using the machine to balance myself (if that makes sense). Weight was 10kg lighter but even when I warm up with the bar only, I don't get that low.
Fark squatting in the smith machine even when the Olympic bars are being used. I just do goblet squats instead (yeah, can't use the same weight but it still pummels my legs well with a 50gk dumbbell lol)
because of the pulley system and the controlled nature of the bar (no,you werent needing to control it as much) that 10kg lighter was probably 40kg lighter. generally any excerise on a machine is easier than free weights.
Is it because the assisted lift means more numbers which means more bragging rights to your gymbros or is it about safety?
I've often thought a spotter would be nice at home, especially when I'm going up in weight on something.
How's the whole no cheese thing going Leesh?
I enjoyed a little Camembert last night, just saying...
I'm eating cheese once or twice a week now, however I've stopped consuming cheese and crackers and eating cheese on its own as a snack. Still the same weight so I don't think it's going to make much of a difference now.
The Smith machines at my gym don't have pulleys (no assistance), the bar just slides up and down two poles and looks like it would be heavier than or the same weight as a normal bar bell. Friction of the poles probably adds resistance too.
It's a shit motion though. To me, it's only good as an adjustable pull up machine and I'd rather wait half an hour for squat racks to free up. My mother nailed freeweights bench and squats the first time she tried them, no excuse not to learn how to balance a bar.
Just work on that mobility if you want to squat lower. Everyone can do it, everyone can sit in a seat and pull their knees up to their chest, their body just doesn't trust itself during squat motion.
IMO it's easier gaining weight than it is loosing it, but that's just my personal view others may disagree,
Agree and disagree. Losing weight is only difficult mentally, since ultimately all you need to do to lose WEIGHT is be in a deficit - don't actually need to do any exercise. Gaining weight is easy as hell, since all you gotta do is be in caloric surplus.
Losing FAT while retaining muscle = both physically and mentally difficult
Gaining MUSCLE = physically difficult
There is NO excuse for curling in the squat rack, short of wanting to curl excess of ~45kg (heaviest most fixed-weight dumbbells I've seen go to) specifically with a straight bar.
The smith machines Anytime Fitness have are ever so slightly assisted, but only enough to slightly offset the weight of the bar without any plates (makes bar weight 9kg, and also makes it move much slower without weight)
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
