Flexibility and squat depth is irrelevant.
Max cant touch his toes, squats deeper than anyone here
Its mobility you should be looking at
No one here stretches, but most do mobility exercises, although Max and Martin don't.
What they do do is perform every rep of every set to its correct range of motion, even warm ups with empty bars
Just food for thought
Dan does, he is very tight in the hips, yet can kick over anyones head (2 x World Kickboxing Champ). Very flexible, yet lacks mobility in the hips.
Mobility World seems to be the best site for that stuff, has some very good information on there
had to squat on the smith machine last night, found i could go much much lower then when I do with the bar by itself. Probably another 2 inches. Not sure why, I wasn't leaning back into the squat and using the machine to balance myself (if that makes sense). Weight was 10kg lighter but even when I warm up with the bar only, I don't get that low.
Fark squatting in the smith machine even when the Olympic bars are being used. I just do goblet squats instead (yeah, can't use the same weight but it still pummels my legs well with a 50gk dumbbell lol)
because of the pulley system and the controlled nature of the bar (no,you werent needing to control it as much) that 10kg lighter was probably 40kg lighter. generally any excerise on a machine is easier than free weights.
Is it because the assisted lift means more numbers which means more bragging rights to your gymbros or is it about safety?
I've often thought a spotter would be nice at home, especially when I'm going up in weight on something.
How's the whole no cheese thing going Leesh?
I enjoyed a little Camembert last night, just saying...
I'm eating cheese once or twice a week now, however I've stopped consuming cheese and crackers and eating cheese on its own as a snack. Still the same weight so I don't think it's going to make much of a difference now.
The Smith machines at my gym don't have pulleys (no assistance), the bar just slides up and down two poles and looks like it would be heavier than or the same weight as a normal bar bell. Friction of the poles probably adds resistance too.
It's a shit motion though. To me, it's only good as an adjustable pull up machine and I'd rather wait half an hour for squat racks to free up. My mother nailed freeweights bench and squats the first time she tried them, no excuse not to learn how to balance a bar.
Just work on that mobility if you want to squat lower. Everyone can do it, everyone can sit in a seat and pull their knees up to their chest, their body just doesn't trust itself during squat motion.
IMO it's easier gaining weight than it is loosing it, but that's just my personal view others may disagree,
Agree and disagree. Losing weight is only difficult mentally, since ultimately all you need to do to lose WEIGHT is be in a deficit - don't actually need to do any exercise. Gaining weight is easy as hell, since all you gotta do is be in caloric surplus.
Losing FAT while retaining muscle = both physically and mentally difficult
Gaining MUSCLE = physically difficult
There is NO excuse for curling in the squat rack, short of wanting to curl excess of ~45kg (heaviest most fixed-weight dumbbells I've seen go to) specifically with a straight bar.
The smith machines Anytime Fitness have are ever so slightly assisted, but only enough to slightly offset the weight of the bar without any plates (makes bar weight 9kg, and also makes it move much slower without weight)
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
