Yeah it's excusable to use it when you've got no alternatives and can't weight around. Personally I only use the smith machine for shrugs and the occasional behind-head military press application (out of laziness).
what about standing military press in the squat rack? I find using the longer bar a million times better then the short barbells.
CURLING :P I also agree with your point on military press with the Olympic bar. It's strange how 40kg with the Olympic bar feels much more natural than 40kg with the fixed barbells.
There is NO excuse for curling in the squat rack, short of wanting to curl excess of ~45kg (heaviest most fixed-weight dumbbells I've seen go to) specifically with a straight bar.
Still a more horrible excuse than Twilight.
No reason these twits can't stand in front of a mirror elsewhere and pick the barbell up off the ground. If they can't supinated deadlift more than they curl, they should probably reconsider their gym routine - nay, life.
I don't
I think I do because I research, ask questions, listen to advice, use iifym and I'm making gains in the gym
If it were correct, you'd be mad to ask the question. I mentioned correct, correct would be what works for you.
Just because someone does something that is known to work, doesnt mean they are doing it right for it to work for them. as i'm sure you are aware.
either it is not implemented properly or you arent patient enough.
Agree Jangles. There are plenty of people who go to the gym for years and never get anywhere close to what they want because they falsely believe they are doing things correctly. Then it becomes a case of "gym just doesn't work for me" or "this is as good as it gets for me".
There are also people who chop and change the advice they get because they don't like one part of if or they are OCD about doing things a certain way = YNDTFP
IIFYM is to obsessive for me, I go by calories and making sensible choices (i.e not eating my calories in 'whatever' purely for the sake of it). Still working so far, but finding it harder to avoid processed carbs etc now that I'm living with the mrs.
I think each mind and body will have a natural level it likes to sit at, by that I mean that you exercise and eat well (your mental commitment) and do all the right things (your physical commitment) and the weight will drop to level, say "X", easily enough or within a a reasonable time frame.
From there, the effort taken to drop further KG's may be disproportionate if you get me. You were exercising 4 times a week for 1hr, but to drop another 5kg requires 6times a week for 90mins, a considerable increase for what appears to be a smaller gain.
It's the same trying to get stronger, people talk about noob gains, my squat and DL are really evident of this. The first chunks come easy and with only a reasonable commitment in time/effort. To get properly strong requires much larger investments of time/money/ etc.
So in the first 3mths you double your squat, then it takes 9mths to do the same again, then it takes 12mths to add another 25% and the time taken to increase goes up and the gain gets smaller.
It's a trade off.
I wouldn't stress to much about the numbers on the scale, I've seen plenty of girls who look fantastic and weigh far more than girls who don't eat or exercise and look like jelly wafers (thin and wobbly).
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
