The guys using pads for squatting do
lol
http://www.bodyscan.com.au/dexa-technology.php
Best to book 2-3 sessions, much cheaper
Been meaning to book a few scans, pointless getting a single session anyway IMO
What's wrong with your PayPal? I'd prefer to do it with that for easy refund if it doesn't go ahead for whatever reason. Maybe I can send you a request for funds?
Will send them an email tonight and find out what I have to do to get a sample tested.
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
