I believe there is a storage unit being auctioned off in Sydney tomorrow filled with ex-commercial gym gear/equipment.. Trying to get details, however my contact isn't being as forthcoming as he should! Lol.
So if anyone is interested, will post up details when I manage to get a hold of them.
  • Like 1
Pull ups and benching will usually suffice in the shoulder development department. If you're talking about "aesthetics", well, you're probably asking in the wrong forum..
If you are talking shoulder strength then pullups and bench arent going to cut it , unless you are wanting pretty ordinary abillity. Military/push press over bench any day. Balanced with external rotation movements to build strength through that motion. Thorasic spine and shoulder girdle strength are most peoples weak links.
Speaking as someone who used to do strict military press with more than 100kg for reps, including cleaning the weight (not off a rack)
Edited by rev210
agreed
You seem fairly knowledgeable in these areas rev, care to offer any insight on good ways to strengthen thoracic and shoulder girdle?
On another note, how do you guys stop your legs from bleeding doing deads? Long socks?
You don't have to drag the bar up your legs; you can pull the bar just in front of the shins etc.
Just give it time and practice...
Haven't had scraped shins for ages, but I used to get scabs when I was first starting out.
Socks / cup of cement, same thing :P
Haha doesn't bother me, but some people get worried if, god forbid, a drop of blood gets on the bar.
Curiously, if you can do normal deads how come you're doing Romanians?
Changed my training style a while back and these fit well into what I'm doing
I wear pants whenever I do deads, has helped but I still get bruising
mfw I have bigger calves than everyone in the gym apart from the 1 competetive bodybuilder and don't do any calf isolations at all.
regretting doing heavy db rows yesterday then heavy deadlift and volume squat today - lats and upper back did not want.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
