Spotters on bench: half of them get it right, the other half swoop in to save you at the slightest sign of a struggle. This is a person who likely has never pushed maximum intensity during their own workout for they see their struggles in your own; a breaking point for failure.
Seriously, don't touch the f**king bar until I drop it on my chest!
Tried d-stunner PWO tonight big caffeine hit 300mg a serving, tastes mega chemically and the aftertaste stays around for half an hour or so. No real beta tingles and no crazy vain pump or anything. Yet to see how bad the crash is but I have a contain of the stuff so will keep updated :)
LOL I love lifting without a spotter... means if I f**k it, then I wear the consequence (have worn a 42.5kg dumbell before LOL).
thats ^ just dumb.
Spotters are there to assist - however it's mostly a mental thing as most peeps I see being spotted do most of the work
I had a spotter to help me bench (big Matt 6"5 or 6"6 145kg and super strong - no roids btw)
Got me over the 100kg bench with him
I did all the reps myself till I fatigued and on the last one and my left arm just let go
If it wasn't for him my arm / shoulder would been super foutu (fkd)
Spotters only intervene when they need to
  • Like 1
Most importantly your spotter actually has to be paying attention/big enough to actually help. Have seen people doing decent bench weights with spotters that couldn't lift a cup of flour
  • Like 1
I have spotted people at my gym benching 150kg Nick. If you position yourself with one foot in front of the other and lift the bar straight up if you need to with a mixed grip it's not hard...
One foot infront of the other is usually appreciated as it prevents nuts to the face lol
They don't have to be strong, only enough to make up the 10% or so of strength that the lifter loses at point of failure. Unless they are a shitflamin mongrel and make you do all the work, the bench presser should still be pressing up to help you get the bar up and can still push at least 90% of the weight.
I don't see the point to spotting if the spotter is just helping the lifter through their whole set...drop the fkin weight if you can't lift it by yourself. They really should only be there to help you if you are about to drop it on yourself / pushing the last rep out and can't get it by yourself.
I only use a spotter on my last set when I go for max reps.
I tell the spotter to walk in when I say now and getthe weight in the rack.
I LOL at people who get spotted from my their first set till their last on nearly every exercise.
I think its a bro thing and they like their friends junk sitting on their forehead.
  • Like 1
lol, couple weeks ago I saw a spot n twat combination going at it for 100kg bench. Helped him a lot from the push off right up until the last rep, and all the reps were shallow; about half way to the chest. I thought, what's the point, are you gonna go home and say you benched 100 for x reps? Bet he couldn't do one on his own. Drop it to 90kg and do it properly fgt. Spotter there to save you, not to do it for you!
I turned away before the set finished because I didn't want to hear the cringeworthy "all you bro" at the end of it.
P.S. Junk should not be in a man's face any longer than necessary, thus only in an emergency where it's a choice between a heavy bar coming down on the chest/neck and having some guy's nuts in your face, should you elect to have a spotter help you...and even then...tough call...
  • Like 1
The other thing to remember is people don't look at alternate exercises to build strength in a certain area. ie will always go for loading up a bar to look impressive, vs slower and better technique with lighter weight dumbells.
What about a woman's face?
  • Like 1
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
