Tough as. Month off due to injury?
I shrivel at the thought of my week off, let alone a month :(
had back injury, then had sickness, then had anxiety, which made me feel physically sick even thinking about gym.
Put clean and press back into my routine.
Don't know how I ended up not including it for the last 3 months.
I also had 3 weeks off, its good to get back into it, it also had been a while since I laughed at pencil necks doing curls and flys, ahh, good times.
That's rough as! Hopefully your first sesh back was a good one :)
On a seperate note, I squat ass-to-grass but find every now and then, I feel a bit of pressure around my knees. I have checked my form and knees aren't bending in but not sure if this is normal? I feel like I can lift more if not for the pressure build up around the knee area when squatting. Not painful, just uncomfortable :(
Thanks, was 10kg off my squat which was to be expected I guess. I feel pretty depressed about gym, but I think I'm just depressed in general.
I get knee pain but my knees bend in. A lot of the time you think your knees aren't bending in, but you have to deliberately focus on an exaggerated, pushing them out movement throughout the squat. Maybe try a wider stance too?
  • Like 1
Considering a month off, only dropping 10kg is not too shabby at all! I missed the week and dropped 5kg :angry:
I normally train by myself so I can only rely on what the mirror is showing me but I guess it is possible that I'm actually bending in more than I can see. thanks for the tip, I'll give the wider stance a go :cheers:
No probs, good luck
Stop watching the mirror, it will screw you up more.
  • Like 1
This
Okay for an occasional form check, but you'll be more focused and "one" with the weight/bar and movement if your only sensory perception of things is the feeling of weight across your shoulders and progressing through the range of motion.
BW 80kg 166 cm, Mil press once a week, 1rm with perfect form is 80kg
10 x 20kg (bar)
Then 7 sets of 5 reps from 55% 1rm to 85% 1rm.
Then alternating dumdbell presses 3 x 10
Then lat raise 3 x 10
Then bent lat raise 3 x 10
Finish the day with some high pulls 3 reps about 5 sets.
I have just gone through a deload of about 10% of my 1rm as I had some time off and my joints were getting sore.
It will set me back a while but I needed to do it.
Pretty quiet in here lately.
How much are you guys overhead pressing? Weight and frequency?
What programming are you using to progress it?
I feel like I will stall soon
Usually 100kg on seated shoulder press barbell or smith. For the last set 10-12 reps. The other two warm up sets starting at 50kg with reps 15-20 range.
If you feel like you are going to stall on a weight and cant lift any heavier try the 5x5 routine and drop your wieight back and build up over 6-7 weeks. I get huge strength increase doing this every time.
I have permanent shoulder injury as well after shoulder recons and still get strong shoulders. i always finish every shoulder day off on the cables as well. Im 100% this is what makes them grow the pump is insance and just do 1 drop set.
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
