Tough as. Month off due to injury?
I shrivel at the thought of my week off, let alone a month :(
had back injury, then had sickness, then had anxiety, which made me feel physically sick even thinking about gym.
Put clean and press back into my routine.
Don't know how I ended up not including it for the last 3 months.
I also had 3 weeks off, its good to get back into it, it also had been a while since I laughed at pencil necks doing curls and flys, ahh, good times.
That's rough as! Hopefully your first sesh back was a good one :)
On a seperate note, I squat ass-to-grass but find every now and then, I feel a bit of pressure around my knees. I have checked my form and knees aren't bending in but not sure if this is normal? I feel like I can lift more if not for the pressure build up around the knee area when squatting. Not painful, just uncomfortable :(
Thanks, was 10kg off my squat which was to be expected I guess. I feel pretty depressed about gym, but I think I'm just depressed in general.
I get knee pain but my knees bend in. A lot of the time you think your knees aren't bending in, but you have to deliberately focus on an exaggerated, pushing them out movement throughout the squat. Maybe try a wider stance too?
  • Like 1
Considering a month off, only dropping 10kg is not too shabby at all! I missed the week and dropped 5kg :angry:
I normally train by myself so I can only rely on what the mirror is showing me but I guess it is possible that I'm actually bending in more than I can see. thanks for the tip, I'll give the wider stance a go :cheers:
No probs, good luck
Stop watching the mirror, it will screw you up more.
  • Like 1
This
Okay for an occasional form check, but you'll be more focused and "one" with the weight/bar and movement if your only sensory perception of things is the feeling of weight across your shoulders and progressing through the range of motion.
BW 80kg 166 cm, Mil press once a week, 1rm with perfect form is 80kg
10 x 20kg (bar)
Then 7 sets of 5 reps from 55% 1rm to 85% 1rm.
Then alternating dumdbell presses 3 x 10
Then lat raise 3 x 10
Then bent lat raise 3 x 10
Finish the day with some high pulls 3 reps about 5 sets.
I have just gone through a deload of about 10% of my 1rm as I had some time off and my joints were getting sore.
It will set me back a while but I needed to do it.
Pretty quiet in here lately.
How much are you guys overhead pressing? Weight and frequency?
What programming are you using to progress it?
I feel like I will stall soon
Usually 100kg on seated shoulder press barbell or smith. For the last set 10-12 reps. The other two warm up sets starting at 50kg with reps 15-20 range.
If you feel like you are going to stall on a weight and cant lift any heavier try the 5x5 routine and drop your wieight back and build up over 6-7 weeks. I get huge strength increase doing this every time.
I have permanent shoulder injury as well after shoulder recons and still get strong shoulders. i always finish every shoulder day off on the cables as well. Im 100% this is what makes them grow the pump is insance and just do 1 drop set.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
