I'm in two minds about that approach due to risk of injury due to lack of energy/focus and not maintaining good form etc.
What's odd is even when I've had some good eating days and gotten some decent sleep, the fall off in strength between sets is the thing that stands out most notably.
My gym emailed me to say great news, we're doing 100k worth of upgrades for a nip and tuck. I opened it with excitement thinking here come the extra 5 and 10kg plates I've been waiting for (we have a severe shortage of these), along with some more oly bars for deadlifting and another squat rack.
100k of "functional equipment" upgrades. Being installed today and won't impact the free weights area. Farking cuuuunts. Do they know how much actually functional strength equipment that money could buy?!?
I am cutting out the low rep stuff for a while as I have been getting reoccurring back pain from a old injury (dehydrated discs).
German volume training here I come again.
Down to the lightest i have been in years 88kg sitting 11-12% body fat strength starting to hit a wall but still pretty strong. Look flat and bloated from sups and bugger all carbs. Cant wait for another few weeks to switch things around a bit when i get below 10%bf
Joints are a bit sore so belts and straps for pretty much everything
Morning all.
I'm still here, doing little more than maintenance these days due to work, not great sleep, long winter season of illness etc. Lost 5-6kgs (not intentionally and it sucks, but hey, more abs) and am only getting 3x 30-40min sessions a week these days so unsurprisingly my strength/size has/is also going backwards.
Because I cannot easily control the factors affecting it, what's the best approach to try and minimise the losses? Drop the weight so I can get out the full rep/set scheme (3x8 in most cases, 2x15 on squats bu they are only light and are a special case due to my back) or continue doing what I've been doing which is struggle but keep adding sets to get the full volume out. as in 8, 8, 5, 3 or 8, 7, 6, 3 etc.
Good to see you guys (and Leesh) still cranking out your sessions :D
Make sure you calorie intake supports it, especially protein. Concentrate on your compounds with linear progression. 30-40mins should be plenty to get out your sets. If you've gotten weaker, reset, start again.
I'm taking a week off, will have a light session on Wednesday, upping food intake, trying to get to bed earlier, back on multivitamin, daily yoghurt/juice for better immune health etc.
Starting to feel slightly better, at least from the point of view of not catching anything for a few weeks.
That old man struggle is real - as Rev sits there laughing.
Thanks fellas. Yeah, the hips rising early is a bit of a common thing I do. I'm thinking it's related to not engaging my lats enough and thus not "drawing the bar back" quite enough.
Birds I'm 5'9 / 175cm or thereabouts. I think I've got slightly shorter limbs (femur in particular) and longer torso than average, which is supposedly common with my heritage.
I think I'm somewhere between the first and second images in the different types below.
  • Like 1
Must retract these comments
When they said the upgrades wouldn't affect the free weights area, it was a bit of a mistruth, as they have now created a second free weights area
Basically a huge crossfit/lifting/kettlebell station ala my previous gym
Complete with two deadlifting platforms, full size small plates and about 10 Ironedge squat and deadlift bars with some sweet, sweet knurling
f**k yeah
Every time Birds comes to my power lifting gym he has a sad about the bars though because they hurt his hands. I think they are awesome but maybe because I'm used to them. Once you go a texas bar you don't go back.
  • Like 2
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
