I'm in two minds about that approach due to risk of injury due to lack of energy/focus and not maintaining good form etc.
What's odd is even when I've had some good eating days and gotten some decent sleep, the fall off in strength between sets is the thing that stands out most notably.
My gym emailed me to say great news, we're doing 100k worth of upgrades for a nip and tuck. I opened it with excitement thinking here come the extra 5 and 10kg plates I've been waiting for (we have a severe shortage of these), along with some more oly bars for deadlifting and another squat rack.
100k of "functional equipment" upgrades. Being installed today and won't impact the free weights area. Farking cuuuunts. Do they know how much actually functional strength equipment that money could buy?!?
I am cutting out the low rep stuff for a while as I have been getting reoccurring back pain from a old injury (dehydrated discs).
German volume training here I come again.
Down to the lightest i have been in years 88kg sitting 11-12% body fat strength starting to hit a wall but still pretty strong. Look flat and bloated from sups and bugger all carbs. Cant wait for another few weeks to switch things around a bit when i get below 10%bf
Joints are a bit sore so belts and straps for pretty much everything
Morning all.
I'm still here, doing little more than maintenance these days due to work, not great sleep, long winter season of illness etc. Lost 5-6kgs (not intentionally and it sucks, but hey, more abs) and am only getting 3x 30-40min sessions a week these days so unsurprisingly my strength/size has/is also going backwards.
Because I cannot easily control the factors affecting it, what's the best approach to try and minimise the losses? Drop the weight so I can get out the full rep/set scheme (3x8 in most cases, 2x15 on squats bu they are only light and are a special case due to my back) or continue doing what I've been doing which is struggle but keep adding sets to get the full volume out. as in 8, 8, 5, 3 or 8, 7, 6, 3 etc.
Good to see you guys (and Leesh) still cranking out your sessions :D
Make sure you calorie intake supports it, especially protein. Concentrate on your compounds with linear progression. 30-40mins should be plenty to get out your sets. If you've gotten weaker, reset, start again.
I'm taking a week off, will have a light session on Wednesday, upping food intake, trying to get to bed earlier, back on multivitamin, daily yoghurt/juice for better immune health etc.
Starting to feel slightly better, at least from the point of view of not catching anything for a few weeks.
That old man struggle is real - as Rev sits there laughing.
Thanks fellas. Yeah, the hips rising early is a bit of a common thing I do. I'm thinking it's related to not engaging my lats enough and thus not "drawing the bar back" quite enough.
Birds I'm 5'9 / 175cm or thereabouts. I think I've got slightly shorter limbs (femur in particular) and longer torso than average, which is supposedly common with my heritage.
I think I'm somewhere between the first and second images in the different types below.
  • Like 1
Must retract these comments
When they said the upgrades wouldn't affect the free weights area, it was a bit of a mistruth, as they have now created a second free weights area
Basically a huge crossfit/lifting/kettlebell station ala my previous gym
Complete with two deadlifting platforms, full size small plates and about 10 Ironedge squat and deadlift bars with some sweet, sweet knurling
f**k yeah
Every time Birds comes to my power lifting gym he has a sad about the bars though because they hurt his hands. I think they are awesome but maybe because I'm used to them. Once you go a texas bar you don't go back.
  • Like 2
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
