Well, after a couple of months of sweating the ID inspection, I got the 34 with NSW plates through Sturt Police today.
I thought that it would be referred to Regency for further inspection but it didn't happen. One of the boxes on the inspection sheet asks if further inspection is necessary but he ticked the 'NO' box......whew. :thumbsup:
Obviously coilovers, lowered slightly, airpods, wheelspacers, Kakimoto Dual N1 exhaust & BBS wheels with 265 rubber are all OK as long as they're within spec and all mounted well.
Now I can finally bolt on all the stuff that I've been acumulating for a few months.
good to hear :thumbsup:
Thanks Cara
hey congrats man!
post up some pics with the new goodies??
Thanks, I'll try.........but its things like bigger garrett turbos, cams, power fc, hks elec boost controller, injectors, fuel pump rail & reg, bigger tube & fin fmic, different air pods, improve existing exhaust with split dump pipes etc, better clutch and a few other hidden things.
Most of that stuff you don't realy see unfortuantely.
what garret turbos u thinking?
Wanted to stay low mount so I've already bought a pair of GT2860R 707160 -5.
No point in going top mounts or big single unless it sees the track or drag strip more than the street.
Not wasting any time are you? 350-400rwkW here we come.
*cough* and some 32s * cough*
*cough* and some stageas *cough*...lol ;)
Seriously though, the 2860rs -5 are basically the same size as the standard turbos from the research ive done recently, just with steel wheels.
Ive just fitted the 2860rs-7 to my 260rs, which in my case was the biggest i could go and keep them low mount cos theres not alot of room under there! The next up from there is either a -9 or -10 which the exhaust housings were too large to be mounted, but also they dont come on boost til very late either so it doesnt make it very streetable as a daily.
Not gospel of course, just what i had found out doing some poking around, so might be something you want to check! :(
*cough* and some stageas *cough*...lol >_<
Not gospel of course, just what i had found out doing some poking around, so might be something you want to check! :P
i think you got the sizes mixed up
2860-5 (2530's) isnt same size as the standard turbos, and -5 is bigger than -7
Had me worried there for a minute :) . Just did some research and found the standard turbos have a .53 housing (actually stamped on the turbos) where the -5 has a .60 & .64 respectively. The -10 has a .64 with an optional .86 housing (too laggy for street and too narrow power band).
Also found out something interesting.....all new GT28 housings out of Garrett now are stamped 2560R but specs are still the same as 2860R....this straight from their website:
For those familiar with our product range, this means that the unit formerly known as "the GT28R" (part number 466541-1) is now in the GT25R family. More specifically, it is now a GT2560R model.
Wow, I can't believe it got through with wheel spacers - it really was your lucky day.
Sounds like your plans are for a nice tough real streetable GTR.
Surprised me thats for sure......probably because the wheels are just inside the guards that he didn't look or care about it.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
