Evening all,
Well, it seems the 'westies' are socialising an awful lot lately, and for those who attended, the last Qld meet was good fun.
I propose we have another: Feb/early march. Bbq, bit of a drive, and plenty of car talk! There are enough new people/ fresh mods that it should be good fun, and a great way to touch base.
I propose a Gold Coast venue this time, but am open to suggestions: What do you guys think??
We had what?.......8 cars last time?? Let's try to double it!
Interested? Reply to this thread, and we can start working on something a little more specific.
https://www.sau.com.au/forums/topic/201008-se-qld-nth-nsw-meetbbqdrive/
  • Replies 100
As a new owner this would be great. I'm sure there's plenty to learn. If one stag gets a stare or ten every day, imagine how confused people would be to see 15! Anyway, if I can come, I will. Gold Coast venue and a Sunday morning and I'll be there!
Ok, I'm thinking Sunday 17th Feb. Meet in the morning between Bris and Gold Coast, bit of a cruise: Bbq in the hinterland, and a bit of a chat, then maybe another cruise in the arvo.
Thoughts?
WOOHOO I may be able to come! :cheers:
Will be moving to brisbane on the 25th Jan so only a couple weeks away now. :)
Looking forward to meeting some of you guys and chatting about all things stagea :P
Been on a couple of cruises here in adelaide, but no stagea-only ones yet.
Afternoon would suit me better but should be able to fit in with whatever goes.
Edited by pixel8r
Bernard, you'll be looking a little pale, I think *cough* *cough*
By the sounds of things, we'll need a late morning/early afternoon.
How's the 24th for evryone (including our poor, sick friend Bernard)???
I am always up for a cruse :D
Be good to catch up with old frends and meet new ones.
I'LL be crusing from walloon. I'll see if i can rustle up a coupel extras here in ipswich. :whistling:
CRUSE 1 8 cars
CRUSE 2 8 cars
CRUSE 3 8++++
I am always up for a cruse :P
I'LL be crusing from walloon. I'll see if i can rustle up a coupel extras here in ipswich. :)
CRUSE 1 8 cars
CRUSE 2 8 cars
CRUSE 3 8++++
:( Excellent.
I'm doing a bit of research/driving with some friends who have motorbikes: plotting a decent drive to a bbq area. Those bike guys know all the good roads...
If all else fails, we can just invade Hugh's place! :)
Should have something sorted by the end of next week.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
