I ran my RB20 for over 3 years with no BOV. And the previous owner ran it like that as well, it was boosted for most of its life and handled backing off at 1 bar just fine. Chuffed like a mofo, and sounded great.
Got bored with the turbo and replaced it with an R33 S2 one, and continued running without a BOV. It was fine as well.
NO BOV = NO WORRIES. Anyone who tells you your turbo will blow up has been brainwashed by the "your car needs an aftermarket BOV for better performance (and more money in my hip pocket peddling junk to idiots)" brigade.
https://www.sau.com.au/forums/topic/201983-is-this-bad/#findComment-3588266
i personally suggest running one. why would you want all that air slamming into your turbo fins then once you get back on the gas you got the little lag from you turbo slowing down. i kno people who ran no bov and their turbos are still ok then i know some that had their shit blow up. you never kno you could be next. id rather spend a couple hundred bucks on a bov versus buying a new turbo sooner than i have to
https://www.sau.com.au/forums/topic/201983-is-this-bad/#findComment-3588368
no bov = stupid
yes its not going to "blow up" your turbo, bit it WILL create more lag in between gearchanges than necessary, i would never run any turbo car that i have without a bov. If you dont want the ptttch sound, plumb it back, easy.
search, this has been covered to death
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/201983-is-this-bad/#findComment-3588463
lol!
it does not created more lag between gear changes lol it does the opposite. nothing wrong with running no bov most drifters dont use bov, and i have personally seen many cars go for years without a bov and big power and no problem what so ever with their turbo.
its a urban myth ...
https://www.sau.com.au/forums/topic/201983-is-this-bad/#findComment-3588518
cefiro's and other nissan family cars equipped with RB20DET's run no BOV's (plumb back or atmo) and have worked fine for their entire lives (all 17 years of it). Granted they always ran on stock boost on stock turbos. Once you start changing factory boost levels and turbos etc, it'd be wise to put one in.
https://www.sau.com.au/forums/topic/201983-is-this-bad/#findComment-3588522
lol!
aahh wat??
your telling me air being forced back into a turbine thats spinning the other way wont slow that turbine down, then once that turbine's rpm has been reduced it doesnt take more time to spool up the turbo the the rpm which is would still be at if there was a bov there???
im the one lol
a mate of mine has a xr6t with no bov and the compressor surge is huge inbetween gearchanges when hes at 20psi, and there IS lag when he changes gears because of this. A bov in this situation WILL reduce spool up (or lag whatever you want to call it) time in between gearchanges when your on boost in the previous gear
its not a myth, its plain old physics
https://www.sau.com.au/forums/topic/201983-is-this-bad/#findComment-3588535
aahh wat??
im the one lol
where does the air go? if the air is not vented, it stays in the pipe. therefore once you jump onto the throttle again and the throttle body opens, and because the pipe is already fulled with air, it goes straight into the throttle body, unlike if you vent it.
this is one of the main reason why pro. drifters don't run bov as it helps with lag between gear changes *weather its noticeable or not is another issue*
also how fast is the turbo rotating/spinning ? 100,000rpm or more, do you think that the amount of air remaining in the pipe has enough force to slow down the turbine when it is speeding at such a high rate?
yes its physic, the air must apply a force on the turbine blades. the turbine blades are rotating which means they also have a force...
so we have:
Air:
F= ma
m= mass of the body (kg)
a = resultant acceleration of the body (m/s^2)
now because the turbine blades are rotating they have a torque.
t=mr^2a
m=mass(kg)
r=radius(m)
a=angular acceleration (rad/s^2)
but that is assuming the turbine blades are a point mass system and we don't consider the mass moment of inertia
what im tring to get at is that one force will be alot larger than the other, so the impact of the small force on the larger force won't be that great....
also their are other issue to consider but its late and i can't remember this stuff off the top of my head would have to go grab my uni books and start quoting lines etc
just to summaries my point. the Force exerted by the air is not great enough the reduce/impact the turbine blades , due to the relative large force it creates (creates is not the best word but you get my point)
Edited by [Michael]
https://www.sau.com.au/forums/topic/201983-is-this-bad/#findComment-3588553
so we have:
Air:
F= ma
t=mr^2a
m=mass(kg)
r=radius(m)
maybe i've lost my point i was tring to get across but yeah
i know what your trying to get at, your thinking along the lines of the force required to slow down the turbine because of its weight cannot be produced by the force that the "trapped" pressurised air stuck in the intercooler piping, i studied physics aswell haha
But think along these lines,
The turbine is spooled from the load that the engine produces, no load = pretty much no boost as you would know with free reving (lets not get too technical and mention antilag)
I dont know why im saying this cause by the look of your post count you've been here for sometime and you know your stuff but anyway,
so when you get off that throttle and slam shut that throttle body butterfly, that compressor doesnt have the driving force from the exhaust turbine that it had when the throttle was on and the engine was under load, so the inlet charge WILL overwhelm the compressor wheel and slow it down. Theres not a matter of ifs or buts, the inlet charge will reduce the turbine rpm, maybe not all that noticeable at lower boost levels, but when the intake charge is up there, i've noticed a difference.
I've noticed with all my cars an instant improvement with a bov, atmo or plumbback. The same xr6t i mention above has a tad over 500rwhp and you can feel it slowing down in each gearchange, then have to spool again. Another mate had a stockish s14, no bov he ran a mid 13, nothing else changed expect a bov and he shaved .2 of a second off his time. If only every noticed nothing but improvements with a bov attached, and that why i stand by my original comment that i will never run a turbo car thats under my name without some sort of vent valve.
Its got abit off topic, and its late so im heading off haha
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/201983-is-this-bad/#findComment-3588569
so when you get off that throttle and slam shut that throttle body butterfly, that compressor doesnt have the driving force from the exhaust turbine that it had when the throttle was on and the engine was under load, so the inlet charge WILL overwhelm the compressor wheel and slow it down. Theres not a matter of ifs or buts, the inlet charge will reduce the turbine rpm, maybe not all that noticeable at lower boost levels, but when the intake charge is up there, if noticed a difference.
fair enough i can see where your coming from :P
from my personal experiences i notice no difference from running no bov to running a blitz bov (350rwhp @ 16psi), but then again it comes down to the car setup, driving style etc as every car is difference.
i understand what your saying about the turbine blade spinning but i was under the impression that even when idle or during gear change the turbine blades are still spinning at very high rpm. Also the reason why i stated the forumlas so show that torque was also affect by angular acceleration not just mass, and one would assume the angular acceleration to be a large number due to the rpm that the turbine blades are traveling at.
https://www.sau.com.au/forums/topic/201983-is-this-bad/#findComment-3588573
sorry i cant quote, internet too slow.
but Micheal said where does the air go? if its not vented it stay in the pipe.
You're right where does it go? it pushes back to the turbo thats the only way it can go. if you got 12 psi in an enclosed area it going to go back the way it came. its just not going to stop and sit there and wait for the butterfly to open back up. the turbo is going to loose rpm then its going to have to spool again.
https://www.sau.com.au/forums/topic/201983-is-this-bad/#findComment-3588571
https://www.sau.com.au/forums/topic/201983-is-this-bad/#findComment-3588574
correct :P the air will go back towards the turbo but how much of the air will hit the turbo. depending on what car you have and your intercooler piping setup will determine the length of pipe and how far the air will have to travel to reach the turbine of course some of the air will come into contact with the turbine blades, and theoretically impacting on the turbine rpm. the time between the throttle body closing and opening is maybe a second, depending on the speed the air is traveling, the amount of air in the pipe and the total distance between throttle body and turbine blades will determine how much air is transfer through the blades and how much air remains in the pipe.
also depending if the air flow is laminar or turbulent, will have an affect on things too.
Edited by [Michael]
https://www.sau.com.au/forums/topic/201983-is-this-bad/#findComment-3588575
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
