Sorry its not a Skyline... but it is faster.
I did listen when you guys told me my GTR was too clean to track, so I had to buy another track car. Its okay, I still have the GTR and although she's a little jealous at the moment, I'm sure she knows how special she is.
Click for more photos
new photos
post-28428-1200883376_thumb.jpg post-28428-1200883422_thumb.jpg post-28428-1200883470_thumb.jpg post-28428-1200883565_thumb.jpgpost-28428-1200883610_thumb.jpg
https://www.sau.com.au/forums/topic/202243-photos-of-my-new-car/
You rock Michele!!!!
Georgie was down at wakie with us today and she now has "the bug" so next time you speak to her, tell her its more fun driving!! hahah (she was passengering and loved it!)
You were at Wakie today? and didn't come say hi? Hmmmphhh
j/k :) did you like the new surface?
Nice one, Michelle!
Now, take out that Holden V6 and drop in a VQ35 with open exhausts!
What was that? Rules for your racing class? What rules? Just tell them it's the new V6 from the VE series... :)
hmmm I just realised... then when you can't come to our track days (cos you're always working!!!!) Georgie can come instead and go back telling you what an awesome time you missed out on :)
BTW, the next hillclimb is on 2nd March, are you working? Are you coming down to Wheels Expo 16th March?
Nick its a Formula Holden/Formula 4000 car, used to Aus main open wheeler class until F3 took over. And they still hold the lap records at almost every Aussie track too.
Michelle is "Hocking" Derek Hocking? If so he still has his race team based up in castle hill next to Hills Motorsports. It would be a good idea to get in touch for any tips unless you have a tame FH guru in your back pocket :)
Nice one, Michelle!
What was that? Rules for your racing class? What rules? Just tell them it's the new V6 from the VE series... :(
Hmmm... I'm sure a VR38TT would fit :)
......"What do you mean official? There's nothing wrong here, it's still a V6!"
Hocking as in Chris Hocking
nice one! very hard core I like it. formula holden is pretty much the fastest class to race in aus so hold onto your hat!
I've been advised to start working on strengthening my neck muscles to deal with the G forces. I'm also told to expect quite a bit of bruising as I am thrown around the cockpit (is it still a cockpit with a lady driver or is it the box office?)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
