Hi guys,
New to the site and stageas too, firstly - fantastic wealth of information you all have collated here - its a credit to you.
Secondly, despite searching I cant find ANYWHERE that supplies different front grilles for the series 1 RS4. I am due to get a stagea soon and I just really dont like the front grille.
Can anyone show me websites or more importantly direct me to a contact that has aftermarket grilles?
Im in the UK if that makes a difference and would love to see some pics!
Thanks all!
https://www.sau.com.au/forums/topic/202410-front-grilles/
check out takeros(.co.jp I think - try a google search) and Masa motorsports (once again not sure of the exact site name). There will be others - just make sure when you search, you use WGNC34 and "body kit' or 'front grille' or 'face' etc when you search.
Give it a few hours, and the guys on here will have a heap of replies with more detailed info than I can provide!
https://www.sau.com.au/forums/topic/202410-front-grilles/#findComment-3593547
Fantastic - I just think the new grille will massively improve the look of the car.
I also want some clear repeaters for the front and side - can anyone help with that?
Thanks again!
https://www.sau.com.au/forums/topic/202410-front-grilles/#findComment-3593554
yeah - what sort of grill do you want exactly? Do a search on yahoo japan and have a look to get some ideas about what is out there. As for the indicators, the front ones are exactly the same as the nissan maxima (use the search function for "clear indicators" ) and the side repeaters are the same as a LOT of different vehicles. I have seen everything from Pulsars to commodores (4 door vauxall monaro to you lads in Pomgolia) you are pretty much only limited to what you can wire in and what will fit in the hole, but there isn't a lot of difference between cars. My choice is the N16 pulsar ones tho.
https://www.sau.com.au/forums/topic/202410-front-grilles/#findComment-3593648
well, mine had a turbo grill with an NA motor (originally) :P
Its just one of those personal taste things I suppose. There are a few RS Four owners here in Aus that want to put NA grills on.......
https://www.sau.com.au/forums/topic/202410-front-grilles/#findComment-3593844
Thanks for the info on the repeaters :D
RE: the grille...
What I have
What I want
Well I got the NA grille from Rob"s wreck caus my stock S1 grille did not have a double Unicorn on it
Maybe I am Stealthier caus I'm turboed?
https://www.sau.com.au/forums/topic/202410-front-grilles/#findComment-3594862
If you weren't on the other side of the world l'd def be interested in swapping grills!!
Hey fuzzy, you should consider it, the postage isn't that bad.... might be way cheaper than trying to find one here or in Japan. Especially if you two swap!
PS I like the NA grill too...I have the Dolphin..... it is one BIG hole..... and no badge fits!!
Edited by Appealing
https://www.sau.com.au/forums/topic/202410-front-grilles/#findComment-3600028
Hey Gareth
i got one of those grills man should come round and check it out
dunno if the misses will let it go though but worth a try
Now thats very tempting!! I'll let u know ... as l'm seriously thinking of doing that and changing my kit.
https://www.sau.com.au/forums/topic/202410-front-grilles/#findComment-3601869
ARGGHHH ... thats what l want!!! I prefer the n/a grill to the turbo one.
+1
I have the turbo grille
the NA grill looks best
Dolphin grille sucks arse IMHO (looks de-ghey with all the bits showing, such as radiator, auto oil cooler (aftermarket), horn(s), radiator air guide (aftermarket))
Id rather NOT see all those bits from the front with the Dolphin grille
lol
https://www.sau.com.au/forums/topic/202410-front-grilles/#findComment-3602790
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
