I was at the tokyo motor show i got lots of pics of the gtr35. Trust me its one awsome car.
I had a look at one few weeks ago, now i have sold my r34 it is temping. but in hong kong there is just no point, to have a car.
on what...your 35 Gtr...unless you got one, its useless as tits on a bull....
So... you couldn't think of anything to do with bits and pieces from a 35 GTR other than fix another 35 GTR???
Sad....
Lets hope they put a capable driver in it...
I am always willing to give it a go.
Or not and we can bid on the destroyed car and use it's bits!!!!!
your already spending enough!!! me too
I'm hoping to see the new RS6, and plenty of skimpy clad promo girls. Isnt that what the motor show was all about????
mmmm RS6....twin turbo goodness.
mmmm promo girls.....nice boobie goodness.
Sad....
well, hmm you couldnt use the head, the block, the clutch, the gearbox, the ecu
so that leaves hmmmm brakes...wheels and front mount but since its gonna be crashed..then yep well done champ you just score nothing except a bit of bent up aluminium
obviously owning an evo has unbalaned some chemicals. that's what happens when you drive a mitsubishi.
seriously, would love to be able to scavenge bits of the new gtr.
anyways, all that aside, is there anything worth while seeing at the motor show this year?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
