That might be right.
When I was told that the n/a had the same gearbox as the 200sx s14, the guy said that my gearbox ,unlike the gtst, had the oil filler hole on the passenger side.
To be honest when I replaced the oil on my gearbox I filled it through the reverse gear switch which is on the drivers side as there was no filler on that side ( I didnt think to look on the other side!).
I have just seen a picture of the 200sx gearbox and it has the swich in the same place so I just need someone who maybe has changed a gearbox on a r33 n/a to confirm this is the same box.
I think that the 200sx may have the rb20det engine in it which , I think puts out about the same power as the rb25de so it makes sense.
I was told that the 200sx had these gearboxes in until 1999.
I dont want to chase a gtst gearbox if it doesnt fit and a 200sx gearbox is supposed to be easier to come by.
As the n/as seem to be very popular in Australia maybe someone out here knows.
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3604774
since you're from england, i'm not sure what you designate to be the 200sx.
but here in australia, the 200sx is the s14/s15 with the sr20det motor. all the silvias use the ca18de(t) or sr20de(t) engines.
i have never heard of the rb gearboxes being interchangeable.
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3604856
I was told the gearbox was the same for the 200sx between 1994 and 1999. I think that up to 1994 the 200sx was the s13 and between 1994 and 1999 it was the s14.
If anyone has a r33n/a with a rb25de engine in it and have changed thier gearbox they would probably know.
I know there is a lot of non turbo skylines out here .
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3605478
i know you can put an RB20 box with an SR20 bellhousing behind an sr20. i would assume it would work the other way.
however a CA18 box with an RB20 bellhousing didnt bolt straight up behind an rb20 or 25 due to being an inch too long. also RB30 boxes also work.
to see if its going to work get someone to measure an SR20 gbox for you and compare it to yours. the bellhousings are all interchangeable between SR, CA and rb20
Edited by adam87
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3605718
dont think so
i think you will find that the bolt pattern is different
if they were the same i think you would find a lot of silvia owners going to a stronger rb25det box then the notchy 6 speed on the s15 and the weaker input shafted s14/s14a items
like eug said, the rb20det box is the same as the rb25de
rb20det's came out in r32 gts-t's, cefiros, laurels, r32 gts-4's (but in awd configuration) and a few others that i cant think off atm
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3605720
dont think so
what i said is from personal experience. i did not mention anything about 25 boxes, rather sr20,rb20 and ca18 boxes.
many silvia owners are using 25 boxes but the bellhousing is a cut and shut and so is the tailshaft.
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3605759
so what you are saying is that the 200sx s14 has rb20det engine and the rb20det engine would have the same gearbox as the rb25de.
Ive got a rb25de engine so the 200sx s14 box should fit mine.
Yeah???
no the 200sx has an SR20 engine.
it should fit but you will need to take your existing bellhousing off and put it on the sr20 gearbox. before you buy the SR20 gearbox have the owner measure it up for you
okay - there you go
put it this way - it would be much easier to source a 2nd hand rb20det or rb25de box then do a cut and shut bellhousing mod to fit a sr20 box behind a rb25
you dont seem to understand what im saying. he can bolt his current RB25de bellhousing onto the SR20 gearbox.
theres no need to cut and shut bell housings for this application.
all he needs is an SR20 box with an RB20 or RB25de bellhousing. you then take the SR20 bellhousing off the SR20 gearbox and bolt the rb20 or rb25de bellhousing on to the SR20 gearbox.
All SR20, CA18 and RB20(RB25de) bellhousings are interchangeable between gearboxes.
all i recommend he does is have the length of the SR20 box measured from the sandwich plate in the middle of the box to the end where the driveshaft bolts in.
Edited by adam87
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3605924
gotcha now
now the next thing - it might work, but would it be actually worth it???
the rb's are 6 cylinders and put out more torque then the sr20 4 cylinders
wouldnt it be more economical to spend a bit more dosh to get a 2nd hand rb25de/rb20det box then potentially break some sr20 boxes???
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3607257
Where I am you can pick up a 200sx gearbox a lot cheaper than a skyline one.
Also there are a lot more of them around so yes if I could pick up a decent Skyline box it would be the best thing but if a good 200sx box will fit, great!
Just one other thing. After I found that I did not have a gtst box I also found out that my box holds about 1.5 litres less than the 4 litres I put into it.I drained a load of oil out and the boxs seems to crunch less. Its gone from crunchy to a bit notchy( which I can live with).
Hopefully it will stay that way, if not I can fall back on what I learned here.
Edited by petethepom
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3608558
as adam87 said, the actual gearbox side of things are exactly the same, same internals, same strength. Its only the bellhousing which differs as obviously the bolt pattern on a sr is different to a rb. Change the bellhousing over to suit the rb and it will work fine.
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3626514
I noticed you said you filled your GB with shockproof heavy gear oil.
Wouldn't it have been better to use either a Shockproof Lightweight or MTL or MT90? Most guys over here that use redline use either of those for the GB, not heavy weight. In fact i'm using heavy for the diff and lightweight for th GB.
Just a thought, it might help better with the crunching. I noticed it improved the smootheness and eliminated the 1st to 2nd gearchange crunch/clunk.
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3653838
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
