That might be right.
When I was told that the n/a had the same gearbox as the 200sx s14, the guy said that my gearbox ,unlike the gtst, had the oil filler hole on the passenger side.
To be honest when I replaced the oil on my gearbox I filled it through the reverse gear switch which is on the drivers side as there was no filler on that side ( I didnt think to look on the other side!).
I have just seen a picture of the 200sx gearbox and it has the swich in the same place so I just need someone who maybe has changed a gearbox on a r33 n/a to confirm this is the same box.
I think that the 200sx may have the rb20det engine in it which , I think puts out about the same power as the rb25de so it makes sense.
I was told that the 200sx had these gearboxes in until 1999.
I dont want to chase a gtst gearbox if it doesnt fit and a 200sx gearbox is supposed to be easier to come by.
As the n/as seem to be very popular in Australia maybe someone out here knows.
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3604774
since you're from england, i'm not sure what you designate to be the 200sx.
but here in australia, the 200sx is the s14/s15 with the sr20det motor. all the silvias use the ca18de(t) or sr20de(t) engines.
i have never heard of the rb gearboxes being interchangeable.
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3604856
I was told the gearbox was the same for the 200sx between 1994 and 1999. I think that up to 1994 the 200sx was the s13 and between 1994 and 1999 it was the s14.
If anyone has a r33n/a with a rb25de engine in it and have changed thier gearbox they would probably know.
I know there is a lot of non turbo skylines out here .
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3605478
i know you can put an RB20 box with an SR20 bellhousing behind an sr20. i would assume it would work the other way.
however a CA18 box with an RB20 bellhousing didnt bolt straight up behind an rb20 or 25 due to being an inch too long. also RB30 boxes also work.
to see if its going to work get someone to measure an SR20 gbox for you and compare it to yours. the bellhousings are all interchangeable between SR, CA and rb20
Edited by adam87
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3605718
dont think so
i think you will find that the bolt pattern is different
if they were the same i think you would find a lot of silvia owners going to a stronger rb25det box then the notchy 6 speed on the s15 and the weaker input shafted s14/s14a items
like eug said, the rb20det box is the same as the rb25de
rb20det's came out in r32 gts-t's, cefiros, laurels, r32 gts-4's (but in awd configuration) and a few others that i cant think off atm
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3605720
dont think so
what i said is from personal experience. i did not mention anything about 25 boxes, rather sr20,rb20 and ca18 boxes.
many silvia owners are using 25 boxes but the bellhousing is a cut and shut and so is the tailshaft.
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3605759
so what you are saying is that the 200sx s14 has rb20det engine and the rb20det engine would have the same gearbox as the rb25de.
Ive got a rb25de engine so the 200sx s14 box should fit mine.
Yeah???
no the 200sx has an SR20 engine.
it should fit but you will need to take your existing bellhousing off and put it on the sr20 gearbox. before you buy the SR20 gearbox have the owner measure it up for you
okay - there you go
put it this way - it would be much easier to source a 2nd hand rb20det or rb25de box then do a cut and shut bellhousing mod to fit a sr20 box behind a rb25
you dont seem to understand what im saying. he can bolt his current RB25de bellhousing onto the SR20 gearbox.
theres no need to cut and shut bell housings for this application.
all he needs is an SR20 box with an RB20 or RB25de bellhousing. you then take the SR20 bellhousing off the SR20 gearbox and bolt the rb20 or rb25de bellhousing on to the SR20 gearbox.
All SR20, CA18 and RB20(RB25de) bellhousings are interchangeable between gearboxes.
all i recommend he does is have the length of the SR20 box measured from the sandwich plate in the middle of the box to the end where the driveshaft bolts in.
Edited by adam87
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3605924
gotcha now
now the next thing - it might work, but would it be actually worth it???
the rb's are 6 cylinders and put out more torque then the sr20 4 cylinders
wouldnt it be more economical to spend a bit more dosh to get a 2nd hand rb25de/rb20det box then potentially break some sr20 boxes???
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3607257
Where I am you can pick up a 200sx gearbox a lot cheaper than a skyline one.
Also there are a lot more of them around so yes if I could pick up a decent Skyline box it would be the best thing but if a good 200sx box will fit, great!
Just one other thing. After I found that I did not have a gtst box I also found out that my box holds about 1.5 litres less than the 4 litres I put into it.I drained a load of oil out and the boxs seems to crunch less. Its gone from crunchy to a bit notchy( which I can live with).
Hopefully it will stay that way, if not I can fall back on what I learned here.
Edited by petethepom
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3608558
as adam87 said, the actual gearbox side of things are exactly the same, same internals, same strength. Its only the bellhousing which differs as obviously the bolt pattern on a sr is different to a rb. Change the bellhousing over to suit the rb and it will work fine.
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3626514
I noticed you said you filled your GB with shockproof heavy gear oil.
Wouldn't it have been better to use either a Shockproof Lightweight or MTL or MT90? Most guys over here that use redline use either of those for the GB, not heavy weight. In fact i'm using heavy for the diff and lightweight for th GB.
Just a thought, it might help better with the crunching. I noticed it improved the smootheness and eliminated the 1st to 2nd gearchange crunch/clunk.
https://www.sau.com.au/forums/topic/203185-gearbox/#findComment-3653838
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
