they have more bits stashed upstairs than any other import shop I've seen, including just jap's 2 units. mostly stock, second hand stuff, I'm sure courtney can confirm if they have a bonnet the right colour for you
  • Replies 327
Posted Images
My WRX mate should be coming for run as well. PS, I need to be an early start
yeah is there anychance to pre book cos ive got baseball grand final later in the arvo juz wanna make sure i get my car on
hey guys i was in but now i am out, i have been demanded by the fiance to go with her to look at houses to move in to....so yea i got to find a house....i have a feeling this is going to be a very boring process and expensive too.....hope you guys have a excellent day......thanks for the invite
Imm in.
Stock Turbo R33 GTST (for the momment)
RB30 twin cam in build and on the way ohhh baby lol
will there be a catagory for rb30 gtst that next dyno day?
Edited by MR FLWLSS
when you see it, you can tell me it's a girls car.
beat the only sr20 there last time.
it half gtr anyway
gtr injectors
gtr fuel pump
gtr rear sway bar
gtr autronic sm4 plug in.
it half gtr anyway
gtr injectors
gtr fuel pump
gtr rear sway bar
Oh she will
Dont worry about the trash talking, its just half the fun :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
