My Filtermag arrived today from the USA, probably not really worth posting about, but since I wasnt able to find one in Australia I figured I would anyway. The concept is that your oil filter cannot phyically filter out all of the metal shavings produced as part of engine operation. If it could, the filter would have to be so fine that Oil itself couldn't pass through. Instead, the fine iron particles are attracted to the the magnet and removed from the oil circulating through your engine. I tested it on a spare oil filters in the garage and damn it's a powerful mofo! once that b1tch is on it won't come off too easily!
Has anyone else tried them out? Comments?? etc?
So this goes AROUND the outside of the line or something, still leaving the metal in there, just collecting enough of it together, that when you finally take it off, you have a ball bearing of metal ready to be sent through your engine? Or if you leave it on, you have a clog...
Is this correct?
Cause if it is, it sounds like fun :(
I'm guessing it would accumilate in the filter, then when u change filter take it off and turf the shrapnel with it, then put it over the new filter.
Good idea.
Haha well I bought it specifically for whilst running in my new motor, I also have a magnetic sump plug, the g/f's dad has one one of the plugs his Gen III which picks up alot of cr@p too.
Edited by MintR33
Sure mate, I got it from ebay off this guy: Ebay Member
And the product website is: www.filtermag.com
If I remember correctly the website has alot of pics of filter's cut in half... take them as you will, no doubt they only posted pics with the largest build up of fine iron, but in all honesty I can't see how it wouldn't work, since the dirty oil passes through the outside of the filter past the magnet before being pulled through the filter core. I've also heard that the A'PEXi UFO filters use a magnet aswell. The benefit of this one is that you can swap ot over to your new filter with every oil change.
not a bad idea on a new engine since everything is wearing in but i see it doing close to nothing on a engine that was already "run in".
If your engine was turning around metal that is able to be picked up by a magnetic, you have more things to worry about than oil filtration.
SnakOil my ace, ppl run magnetic sump plugs for the same reason. Here you have much more powerful rare earth magnets (i would assume) right where the oil is already turbulent and full 'o' eddys.
Check the site, theres something being picked up by the magnet thats gettn by the filter.
These are absolute gold, one of those "cant believe i didn't think about that" ideas thats cheap as a blowjob. CRD and some other shops incidentally have been running them on thier cars for a while.
Edited by GeeTR
GReddy also make an Oil Filter that has a magnet built in. I have been using these for quite a while, however as far as I'm aware they are being discontinued so this might be the next step for me.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
