Car Model: R32GTST
Year: 1990
Rim size: 17 X 8
Rim name/type: Speedy Hollow Type R
Rim offset: +35
Rim internal diameter: 410 mm
Front Brake brand: R32GTST M Spec
Caliper size: 4 spot
Disc size: 340 mm x 32 mm DBA 5000 Series
Pads: Hawk
Any problems with pad wear or coverage with this setup? Any pics? DBA have told me that the reason my DBA4000s cracked is beacuse i am running the GTSt caliper (intended for a 280mm rotor) on a 324mm rotor so the pad depth on the rotor causes thermal issues within the rotor. Result is a crack. Personally i think its their get out of jail argument...it has merit on paper but there is no way i think thats the contributer to why their rotors crack with track work
Car Model: R32 Gtr
Year: 1990
Rim size: 17x9
Rim name/type: Volk gtu, Desmond somethings, enkei po1's
Rim offset: +22
Face type:
Brake brand: Brembo F50
Caliper size: Big 4 spot
Disc size:
Pads: Mu secret level max 900's (overkill.. i know..)
will fill out rest when i get home
Edited by Angus Smart
Car Model: R32 GT-R
Year: 1994
Rim size:18x10
Rim name: Work Meister S2R
Rim offset : +15
Face type: wtf?
Brake brand: Alcon 4 pot
Caliper size: ?
Disc size: 355mm
Will measure innerdiameter of rim and post up.
cheers
Car Model: R33 GTS-T
Year: 1993
Rim size: 17x8j
Rim name/type: NISMO LMGT-2
Rim offset: +38
Face type: -
Brake brand: Ap Racing
Caliper size: 4-pot
Disc size: 332 (endless)
Pad: Endless
Rim internal diameter: -
Edited by [Michael]
Note 32 mm thick x 340 mm DBA 5000 series rotors, ie, not a Skyline rotor. The R32GTST M Spec calliper is the same as an R32GTR calliper, except the GTR legs are 8 mm longer ie; the pads are the same. So a more valid comparison is 296 mm versus 324 mm in your case. That's 14 mm radius, hardly a big deal as long as you stick to appropriate heat up and cool down procedures. Track days can be a bitch for that, the inexperienced people just don't understand why I complain when they try and make me sit there stationery on pit entry. For additional capacity, the 5000 series are the go and 32 mm is available in 324 mm.
Cheers
Gary
Cheers
Gary
I take it you are running a machine down 343mm rotor (HSV?) What hat do you use on the 5000 rotor ?
I used this setup for years and never a worry. From some time 2002 to 2006, the rotors i took off where still not undersized, but thought i would change them to new DBA 4000 just to make sure that i didnt have any problems. The new DBA 4000 are RUBBISH compared to what i purchased in 2002. So certainly encourage ppl to go to 5000 as they dont seem to have the same problems...lol they also dont have the same slot design :)
Fixed :)
Car Model:
Year:
Rim size:
Rim name/type:
Rim offset:
Face type:
Brake brand:
Caliper size:
Disc size:
OK i can only go on what i ve tested myself.
Car Model: Any
Year: ANY
Rim size: 17 x 9.5
Rim name/type: URAS NS-01 (copys include doritek etc)
Rim offset: +15
Face type: normal
Brake brand: ALCON
Caliper size: 6 pot
Disc size: 355mm
Rim internal diameter: fk nose :)
Car Model: Any
Year: ANY
Rim size: 17 x 9.5
Rim offset: +15
Face type: normal
Brake brand: GREDDY
Caliper size: 6 pot
Disc size: 355mm
Rim internal diameter: fk nose ;)
Car Model: Any
Year: ANY
Rim size: 17 x 9.5
Rim offset: +15
Face type: normal
Brake brand: ALCON
Caliper size: 6 pot
Disc size: 355mm
Rim internal diameter: fk nose :D
Car Model: Any
Year: ANY
Rim size: 17 x 9.5
Rim offset: +15
Face type: normal
Brake brand: GREDDY
Caliper size: 6 pot
Disc size: 355mm
Rim internal diameter: fk nose :(
You can stuff a 355 rotor inside a 17" rim. Nice work.
Any chance of a photo and or the rim internal diameter?
Got it in one on the rotors, I am trying something new this year in hats, I'll post it up once I have tested it out sufficiently.
That's not unusual, old rotors have all the stresses heat cycled out of them. For the 1993 and 1994 12 Hour races we drove around the streets for a few weeks, cycling the rotors for that same reason. We had not one sign of the rotor cracking problems we had in 1992. Same rotor manufacturer, same pads.
So certainly encourage ppl to go to 5000 as they dont seem to have the same problems...lol they also dont have the same slot design :banana:
I agree, for decent track work, the 5000 series are the go.
Cheers
Gary
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
