Hey fellas,
In the tradition of carwash meets, was hoping most of the guys on the west side of Melbourne would like to meet up at the carwash just on the side near the Sunshine cinemas complex area that's close to the Coles Petrol Station...
Date: Saturday 9th of February.
Venue: Carwash @ the side of Sunshine Cinemas complex in Sunshine.
Time: 3pm - will wait until 4pm.
Plan: We take turn washing our rides then we jet off to some locations, e.g. Docklands etc for some photoshoots then go to dinner, e.g. Sunshine, St. Albans or Footscray.
If you're interested, please leave your name down...
I'll start with me and a mate...
Spunky Munky
Slouch
Edited by Spunky Munky
  • Replies 40
Fellas, so sorry for the confusion - I meant to make it next Saturday not this one - it's courtesy to at least give you guys 1 week's notice...
I must be half falling asleep when I had type the invite... so yeah, edited.... it's now next SAT which is 9/2.
Everyone can make it then ah.... see you all there!!
hey guys would it be cool if i rocked up?
im in melb from perth and wona check out some of the skylines around ere and other locations
how many cars do yas think will be there?
is sunshine close to brunswick?
yeah would be great!! But you'll bw in for a 45 min drive from brunswick... but would love to hae you mate....
there will be a photopshop so don't forget to wash your cars fellas!
This sound good! I wouldn't mind taking some pics of ya cars in Docklands. What time you ppls be in Docklands and where abouts? Guess I will probley find ya cruzing around.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
