Guest | hype^ |
ok after getting my car back the other day i went for a drive around my area sunday night...
after reading the "what do u rev to" thread i took every1's advise and only reved to about 2-2.5 with very few hits to about 5-6 when giving it a little..
now i went through the better part of 3/4 of a tank and only did a little over 200K's:confused:
i read in the thread that most ppl get about 500Ks out of a tank..
so whats up with my car? why am i using so much fuel?
its pretty much a stock car.. only a mild rear exhaust and blitz bov (which does cause the car to stall sometimes when braking after boosting)
https://www.sau.com.au/forums/topic/2041-fuel-consumption-question/
  • Replies 75
hmmm.. I get 350km on a full tank.
The only time i ever got more than 400 was when I went on
the Joint Syd/Canberra cruise where i got 450kms.
It all depends how hard you are on the throttle and I think in
your situation, you making up for the time it was off the road
like Georgie.
Guest | hype^ |
bucket - yeh i ordered them dude, i should have em in about 2-3weeks
xrsist - thats just the think man, i was taking it easy (shifting at about 2-2.5) with very few bursts to about 5or6...
im acually really pissed off, i really gotta learn how to drive my car propperly... i dragged a what looked like stock commonwhore (V6 i think)
i mean i beat him, but not as easily as i would expect.
i mean my car is stock with only like 5-6pound boost (dont ask me why:confused: ) and i had a heavier friend with me.. but still....
Guest | hype^ |
na man i havent had it serviced yet.. iv only done about 2500k's in the 6 days that iv been driving it..
is a injector clean included in as part of standard (5000k)service?
i was gonna take it to advan they said its 150$ for standard service..
na man it was black i think.. i was at the lights at the intersection of mamre and great western hwy next to him.. i just cruised to the next lights where he went around a car to a ending lane to line up against me.. im like, uv gotta be kidding.. i just took off narmaly (prob why i didnt eat him like i should have) but he full floored , so im like kool and took it to about 6 in 1st and 2nd , by 3rd i cought up to him and over took.. :P
  • 2 months later...
for those guys who have installed safc's and have returned improved fuel efficiency's, who did your tuning? any tips on what and how to tune your safc? what ratio did you tune to?
what AFR do skylines (R34 GTT if you know) run stock? 10.5:1 ?
by leaning out mixtures, how did you find your performance? any noticeable increase or decrease?
i'd also like to hear from those ppl who have installed safc's and returned no or worse improvement?
fyi, with cat back exhaust & air filter the GTT averages about 330-350km city driving. add a trip to wollongong and it'll do 410-430km with a couple of spirited hits...
city driving and a old pacific hwy run and it did just over 300km's! thats woeful...
cheers,
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
