Hey Steve-o I don't think you're going to get outa jail that easily mate. You might. but there's a "but".......
All caps- be it mains, big-end or in your case cam caps are a "machined fit". Meaning, in this case, a set of caps are fitted to the head (slightly under-sized) & then line-bored to both "true" the alignment & set the appropriate clearance. It's not just a case of throwing another #2 at it & she'll be right unfortunately........
Having said that I have in the past gone thru collections of odd cam caps to replace a missing one on bike engines. Strip out the valves on the appropriate bank (without losing anything else :rolleyes: ), lay in the cam & start the process-of-elimination by fitting each avail spare cap & then rotating the cam by hand to get a "feel" of whether it's too tight, too loose or just right 'til you find one that will do the job. I knew a girl like that once.......
If the head's already on the motor & buttoned-up, then it all gets a bit more complicated. There are right ways, there are wrong ways & my above suggestion, whilst not technically correct, is somewhere in between. It's your engine, only you can decide what you want to do. BTW to get a "feel" of what's right wrong or otherwise, fit up one of the existing caps, give it a spin & no you can't use this method with the valves/springs in place. If they are, you could try & plasti-gauge the cap in question but I personally have never done this on cam caps under tension from valve springs so I can't comment either way.
I'm assuming you don't have access to a shop or proper measuring equipment either in all of the above.
Good Luck & let us all know how you go.
yeah, it's even more crucial on an L6 as the cams are so long. plenty of RB26/5/0s out there with snapped cams even just from not being torqued up quite right or in the right order. wrong sized cap will be a problem.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
