Guys I have just fitted 18" 9.5" +12 TE37 to my 32 GTR, the only issue is the tyres are 265 (they were on them) Now the car does scrub a bit on the left front when i hit a big bump, otherwise its seems ok.
What has anyone done to fix this or whats the best solution ?
Raise the suspention?
Take the plastic inners off and roll the guards
or put 245s on the front.
Thanks Gys I will post somes pics of the car as soon as I have them (i have tein super streets in my car)
https://www.sau.com.au/forums/topic/204196-wheels-scrubbing/
  • Replies 51
Roll your guards, if that doesn't help, try to find out where it's rubbing and use your hammer! Depending on how low it is, don't touch it. Make the car fit the wheels. :banana:
Post up some pictures, I want to see how they sit.
Here are a few bad pics, its raining here today so I will get some good side on ones so you can see the gap better.
And Also can anyone tell me the law in regards to the tyres sticking out past the guards, is it the furthest part of the wheels in my case the edge of the tyre and the lip of the guards ? as my tre edge is about 1cm past the lip of the guard but not further then the flared guard itself, I think 245s would brind it in line with the lip.
Edited by Mark0
That doesn't look too bad. Try rolling the guards first and if they still rub, just get new tyres or ignore it. haha. Don't raise the car.
As for the wheels sticking out law thing, it's usually anything past the guard is a defect. So if your tyres are out, but wheels are in, that'll still be a defect and vice versa.
And one more in the rain :)
Well the front tyres are about 40% so you recon leave em let em scrub out then get 245 all around, Does anyone have a 32 GTR with 18" x 9.5" +12
What size tryes do you have on them and if they are either in line with the guards or under on the back are they 245 ?
I am not going to lower it anymore, I like being able to get into most driveways, I will maybe look at either getting tyres or see who can roll guards at the Gold Coast and see if that can flare them out a little bit more (on the back) not sure where the sheels are scrubbing opn the front yet, will have to investigate.
Ok thanks Hey alex I have found the main problem my tyres are hitting the front of the Sideskirts, Really badly I drove it today and it basically bent the metal holding the front of the side skirt forward I have since bent this back and checked both sides, they both hit check out the pics to understand, What has anyone done to fix this, cut some of the side skirt off ? take the small front section off ?
Right hopefully problem is sorted, I pulled the 2 front guards off, grinded the sides as close as I could to the screw holes hammered the wall where the guards screw onto back and now I have about and inch clearence both sides turning the wheel full lock both ways, fingers croshed.
Bugger DMR, means I would scrub with 245, I just went for a spin and it seems better, Just scrubbing from the bumps now not when I turn, I might get some camber on the rears to see if I can get the tyre inline or under the guard so its legal, not sure about camber on the front will it help or will it get closer to something on the inside.
Can anyone tell me how many k's roughtly they get outa tyres when putting camber on them ?
^^Guess depending on how often you drive ya car. I got new tyres about 2 and a half years ago and need new front tyres soon. My cars not driven that much, for about 2 years only done about 37 000 k's.
Edited by (00)SKYLINE(00)
I was thinking maybe to add rear adjustable upper arms (i thinkt hats what i need) to allow me to change camber so the wheels fit under the guards at the back, then I will see how bad scrubbing is and go from there. front scrubs under big bumps.
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
    • Looks fancy But after having a look, prior to its installation, I noticed that the yellow looking power steering reservoir would look crap next to this So I have this incoming..... Much cheaper than the Moroso and has great reviews (yeap, it's a Moroso knock off)
    • Can we place bets? My money is on there is always the option to use the 1 way profile. So the diff is either 2 way and 1 way, or 1.5 way or 1 way.
    • I also used Knox driveshafts when I the slip yoke T56 to the 3bolted TR6060 type. I believe I was one of his first jobs as it literally changed hands when I was there, started by the old owner and finished by the new. Everyone seemed pretty great about it. So wasn't shy/seemed pretty knowledgeable when dealing with weird custom people like me.
