hi everyone,
just wondering if anyone can help me out.
i have a r33 gtr with these mods, and just wondering what times should the be running what else do i need to get into a high 10. also whats sort of boost should i be running???
cheers Tom
blue printed bottom end
Aries forg pistons
2 x hks 2530 turbines
n1 oil pump,
nismo 5 layer steel gasket
reco head
ported exhuast manifold
custom twin dump pipes
hks exhuast
Exedy heavy duty clucth
nismo short shift,
microtech computer lt8
trust twin entry intercooler
Arc intake air box
Tein full adjustable suspendsion,
Denzo 700hp fuel pump, , full nismo
oil catch can
sard 666cc injectors
g-reddy electronic boost controler
https://www.sau.com.au/forums/topic/204515-just-a-couple-of-qs/
Cheers,
I asked the guy before they put it in and said it was good for over 300kw and my car is making 293kw ??? thanks for that
Yeah but for how long?
My car has one of those clutches. It's pretty much garbage compared to a decent twin plate.
Also what RPM should you launch an r33 gtr at to be on the safe side???
"Safe side" (assuming you mean from the mechanical sympathy point of view) and 10s 1/4 times are contradiction in terms. With the power you have a 10s is possible only with good tyres and a very hard launch.
I need to launch at ~6k to prevent bogging down, but this obviously takes it's toll on the drivetrain over time. Clutch failure is the most obvious liklihood, but gearbox failures also aren't unknown (particularly with a hard change into 3rd).
I didnt think 300rwkw was enough to do a 10 in an r33?
Same here....
the hardware sounds up to it but it seems as if you need a better tune to free up some power, or maybe the 293kw run was done at 12psi or so :P
well you lose more power with the all wheel drive and the gts-t is lighter but its no good if you dont get the power to the ground. but im not going to say anything because i dont know for sure. Thats why i asked, i would like to know. theres not alot of GTR where i live.
ok sorry about being a little short, but there have been a lot of stupid questions lately, and sometimes innocent ones get put in the same basket.
awkws are better, because if you disengaged the fronts on a R32 GTR with 300awkw you'd end up with 320rwkw - 330rwkw.
BUT you'd also lose 35% of your traction.
You have the hardware, simply get someone that can tune and crank her up to 350awkw and run some 10's :P
If it helps, with 280kw @ all four, I run a 11.8 @ 117mph in my R33 GTR.
I've now got 318kw @ all four and am running next Wednesday. I'll let you know how I go, I reckon 11.5-11.6 :D
I reckon you'll need 350kw @ all four to run a 10 in a R33 GTR... minimum :P
What boost are you running?
Edited by TommO
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
