Make: Nissan
Model: 1992 R32 Series II Gts-t
Milage: 159,000km *Mostly Freeway Km *
Transmission: 5 spd Manual
Colour: Gunmetal, Paint has an Excellent Shine!!!!
Currently registered? 10 months rego!!!! Registration til Mid November
Price: $12,000 o.n.o
Contact: Matt on 0404028383 or [email protected]
Comments / Modifications:
GTR Wing and Skirts
Apexi Carbon Fibre (YES REAL!!!) Strut Brace
Motor is in standard condition (Perfect Compression, Excellent Fuel Economy (Avg 430km per tank!)
Splitfire Coil Packs
Turbosmart Bleed Valve
HKS Pod
HKS Exhaust from Cat
High Flow Cat
Gearbox was rebuilt about 2 years ago, still nice and tight
Exedy HD Organic Clutch fitted
Slotted DBA Front Rotors w/ Carbon Brake pads
Suspension redone, including replacing all bushes with nolathane
17x8.5 and 17x9" Enkei Lightweight Japanese rims. These are forged and monoblock construction. Very light! Good tyres still on board
8 Point Imobilizer with Remote Entry and Keypad for extra saftey!
Clarion MP3/CD Player with Response Splits up front and Fusion 6.5"s in the rear
Timing Belt, Belt Pully and Roller were all changed at 100,000. Replaced with Gates Racing Kit
I've kept this car fairly standard except for a few tweaks to improve the handling and braking of the car. I've avoided modifying the engine as the car is fast enough for a little fun, and I'd prefer the car not to break down all the time like some other modified cars I know. The car has been looked after by me, A skyline enthusiant, Always serviced, and kept in either a garage or a carport for most of it's life. This R32 even has all the Air Vents intact!!!! :banana:
I'm Regretfully selling my R32. Apparently it's time for a 4 door car... :ermm: I've owned this car for 3 years and besides the usual wear and tear this car has never caused me a drama. If your looking for a nice car that won't cost a lot to maintain and will always be there for you, this is the right car for you! Also, it's good condition would be a good start for somebody looking for a fresh car to build up on. This car is in a whole lot better condition than most 32's getting around!
I've taken the car WSID Twice, It's best time was a 14.01 (I think) Very good time for a stardard motor!! The car has demonstrated it's excellent handling at a couple of skid pan days. The car has never been taken out on a real track though.
The only negetive aspects of the car are the front bar has a crack down the bottom, which can be plastic welded. I never got around to it as I was always contemplating fitting a GTR Bar. There is a little bit of rust in the bonnet, under where the GTR Wing bolts down on one side. Apart from that... it's beautiful!
The car has been Dyno'ed and gave out 143KW at the rear wheels.
PM, Email, or Call me to arrange an inspection, act fast though as clean cars like this don't come up every day! My number is 0404028383, I'm lcated out towards Penrith.
Images:
Edited by MaTBoY
https://www.sau.com.au/forums/topic/204793-fs-1992-r32-gtst-t-sydney/
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
