  • Replies 45
Skizo,
I need to order some parts form Nissan to fix my rear axle clicking noise and have the following parts from a US site.
Any idea if these are the same numbers I can go to Nissan Aus with?
43210-AL505 Bearing Assy rear
39211-73L00 Axle Outer Joint Assy
39241-73L28 Repair kit, Duct boot outer
Cheers
Bobby
Hey mate,
Can only find full details on the first part. The other two it actually does accept the part numbers but I can't pull up any details on them. Not sure what that means as I can't read Jap. Best to call Nissan spares with those numbers, they'll tell you if they are available.
Here's the section you're looking at anyway:-
Hey mate,
Thanks mate,
That's the part. Wanted to make sure that the US part numbers are the same and they seem to be. Now to give Nissan a call :-)
Cheers
Bobby
skizo,
from the FAST will you be able to check the part number and if the cruise control button can be purchased separately or comes as a set with the audio buttons?
it's the one numbered #5 below.. the right hand side. Thank you!
I found it, but where there is normally a part number there is a star and some Japanese next to it. Translation please? Might be in another section. Who knows where the other Cruise Control modules are located/look like and I'll take a look.
Oh and who wants a factory MOMO steering wheel? :D
Oh and who wants a factory MOMO steering wheel? ;)
do u have one? All the ones I've seen have the part woodgrain handle..which I'm not keen on.
run this VIN - factory momo wheel with airbag.
NM35-319191
seee if there are SWC controls for it.
the deviation on the cruise buttons is the radar cruise vs std.
Here are the options that came with this particular one.
Looks like all the part numbers and SWC options for these cars are the same numbers as the V35 one I posted above.
hi skizo,
i have a request for you if you have time..
can you do a search for a replacement 2003 coupe seat?
i'd be interested to see i the seat is different between the normal coupe and the 70th anniversary coupe that had the heated seats
what i'm really trying to find out is if the seat is the same or different and thus if the normal seats have the heaters already installed in them or not
i've just come across some info on G35driver that apparently the non-heated seats in the USA were all pre-installed with heaters in them as there was only one type of seat that could be bought, thus making the heaters work was simple wiring :down:
cheers,
Warren
hi skizo,
i've just come across some info on G35driver that apparently the non-heated seats in the USA were all pre-installed with heaters in them as there was only one type of seat that could be bought, thus making the heaters work was simple wiring :D
cheers,
Warren
Do you have a link Warren?
I was reading G35driver only a couple of days ago about this, and I think it was stated that heaters were not installed on all seats. Would love to find out.
Thanks mate.
I can tell you that teh wiring is there for them. both under the seat and in the centre console. dont have time to rip a seat out ( I have two cars here now) to prove the seats.
Thanks for that Chris. If possible would be great to get it working.
Hopefully as easy as Warren said.
Sorry guys, lifes been a bit hectic for me recently. So i'll catch up when I can.
Just wanted to let you know that I got my hands on a recent version of the US version of the program, so it has all the G35 data in there, so can actually understand some of the writing now! :P
Some part numbers are the same, others are not.
This one is available for you too if you know where to look. Don't ask me.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
