Does the corolla happen to b made in or around 1986, and have a 1GGZE in it or something?
A mate of mine has a supercharged AE86... I don't even know what a starlet has in the engine bay... I thought it was like a second boot...
my friend has a corolla thats supercharged! just wondering if anyone heard of or have a supercharged starlet?
4E-FTE is the jap spec turbo starlet engine. Mate did the conversion to a local model starlet a few years ago, it had guts.
the corrolla would have a 4AGZE from the mr2, zippy little motor.
As for the starlet as mentioned it has the 4E series motor, being such a light car i would expect it to hall some ass :no:
there is no "factory" supercharged/turbo starlets.
I'm sure it's doable, but would be a lot of money for nothing.
I'm assuming you have the aus delivered shopping trolley version.
you can turbo charge that..
or engine conversion from the jap spaec EP82 starlet which has the 4e-fte turbo 100kw engine.
Sydneykid had once mentioned that he knew of someone who had shoehorned a sivler top 20 valve 4age in to one.
those motors are 118kw I think..
was apparently a bit of fun to throw around.
I read about a 20 valve starlet years ago, it was built for circuit racing, power to weight was very good - what it lacked on long straights it made up for it in spades around the corners. From what I remember, the biggest hassle was making an exhaust manifold to fit
Wasnt there an overseas model starlet with turbo from factory?
surely?
I remember seeing a few in Malta few years ago (yep, malta! lol same sorta shape as our late model ones, just different headlights and such)
And then theres the Jap ones from the late 80's
surely?
Yep, in Japan there was the Starlet GT, and the newer Starlet Glanza, both ran 4E-FTE engines.
what's wrong with knowing about cars other than nissans?
take your blinkers off and look around the rest of the stable and see how many cars are around that will hand you your arse.
People of the 90's will know how much fun Switft GTi's were to drive... this is before the import days so some of you can go back to sleep...
the EP82 Starlet GT was about the same weight but had about 10 kw more than the swift.
and more torque due to turbo.
they are light, fun cars to drive.
no dori dori so that rules out some more of you.
a stiff rear anti-sway bar makes a world of difference to the handling.
it is not uncommon to see these cars lift their opposite rear wheel when cornering hard.
small article from back in 1999 in hot 4's when whiteline did a kit for them
http://whiteline.com.au/articles/RH45_star_a.htm
and ofcourse, just like SAU is to skylines..
http://www.austarletclub.com/ is to starlets.
do a little digging. expand your minds.
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
