Im with Kaz, burn the pic of the EVO X. You cant be serious is claiming that fugly thing is Supercool????
I think this deserves to be on the cool , really Supercool is where i would throw it.
Do they have to be new cars because frankly i cant believe there isnt a Countach or a 356 Porsche?
Also the new Ruf CTR3 should get a look in somewhere.
So the above are what i think should be on there.
The following are a few that i personally love, but suppose because they dont cost the earth etc, they probably lose something, but i still think they are hell cool (perhaps more substance then style, but i think that is a style in itself :/ )
And still my favourite concept car was still this, the Audi Avus. The first time Audi trialled the W engine configuration. The result was this 6L 12 cylinder beast using an all alloy body. It came out when i was in High School so something like 1992?
I gotta agree with you there Roy... lose the evo x (bleh) and add some TVR goodness... and anything made by RUF is supercool... a little bit of pee may have just come out while thinking about that Sagaris
glad to see the Alfa 8C is there... but it should have its own board... on plastic... as it would be covered by man milk in no time... I would actually take one over the new GTR, yes you may now flame me
TB- you know my love for the Countach knows no bounds... but I have to keep the coolwall content to current models. Hence no F40 etc
Sagaris though.... yeah OK.
And the Evo stays because it's my wall and I can do what I what :P
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
