Hey Russ... long time no see champs!
Great read about your recent effort in Japan and i have to say the new car sounds exciting to say the least. Look forward to seeing you out there again soon.
PS; I want an invite to the next roast dinner up in the van at Waky!!!
  • Replies 569
Posted Images
hi mate
i need to get down to another one of your days , fantastic days!!
are you racing at the moment? buy a porsche yet or an aussie car! hehe
ahve to catch up again this year
cheers russ
i also mixed you up with paul(dirt grage) on another thread , i have some video's ( skyline group a races) i need to send him.
Hey don't do that again...lol.
Looking good mate, all coming along nicely. Id like to see some of those DVD's as now im in semi retirement (will be back soon with something special though) i need something to keep me from doing too much around the house.
hey paul pm me your delivery address and i will get them sent away tomorrow so you can copy them.
so come on :D whats coming??
also any and all advice welcomed as we are not experts !
thanks guys
Let me know if you need the alignment & weight jacking set up for you. My old man has very accurate scales & alignment gear. Plus a wealth of knowledge & heaps of experience with race car set ups. We used to have the best handling HQ is aus!
thanks guys
If your building an Ozzy Rb30 i think Nizpro or Rajab racing make the billet crank cradles. i also heard that rajab may be having billet cranks made too.
Meh thats just what i heard. Maybe you can run GTRS like dirtgarage hmmm 500kw track car.
Brad
the rb30 bottom has been supplied by hi octane racing , i am pretty sure it has a billet crank cradle but i havent seen it yet ,
dry sump system is being sorted out. yes 500 kw is about what we are looking for, but must keep throttle response and good power under the curve
just thought would post up this vid willo sent me?(thanks mate)
if your bored!!
just playing around at paul's timeattack day in a motorkhana he setup, this was my second run, not reving at all just learning the course, the next run was with some revs! :) good fun tho
if your bored!!
was an awesome day
any vids of ur little launch at the pit exit? :laughing-smiley-014:
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
