haha I was on turn 1 at that race too and saw that camaro powerslide turn 1 everytime!
was awesome!
ROFL.......I watched him do that from in the car.....was f#$king awesome....Stubber really knows how to steer that thing!.....was pissing myself laughing in the car at the time and had a good laugh with him later about it!
I got a few more shots, but they arent the best!
What did you think of the handicap race?
How does it work? i.e. a group starts...then another...then another....but how did they work out when to start everyone?
I liked it(but then again what's not to like when you in a GMS R32)....done right all the cars are suppose to come down the straight together on the last lap.
60's cars get 45 seconds(I was a bit lost on this as the Mustang driven by Des Wall was lapping in the 1:50's)
70's cars get 30 seconds
80's cars get 15 seconds
Then the 90's cars go and we have 5 laps to catch everyone....so I would of had to have been doing 1:41's through traffic to catch Des Wall :P
This is close to what I was temped to do at Lakeside to this Walkinshaw.... it mustn't have mirrors. Jetwreck can attest to that. LOL
your right!......there was 2 more hit's from the VL after that........and before the apex on turn 3.....the VL ended up going off at turn 8!
Let's just say he was not playing nice!
Jetwreck..Were you with the Winfield crew???
I have a few more photos from the awesome photographer Scotty of close calls will post them up...The Aussie cars where getting into it...
Love the Peter Jackson Seirra's epic fail tho............ :) Awesome pics!!
I'm gonna give up my left nut this Sunday to get a photo of me sitting in one of the GT-Rs. Jetwreck, you coming down to Mallala?
nah not going to Mallala.....got some big job's on at work :)
@sinful : After the DR30 broke I was working with Dad on the GIO car...I also did the Handycap race in it!
Oh cool...I know Paul and Jose very well!!
Make sure you say Hi to me next time all I will just go up to everyone and ask "Are you Jetwreck???" LOL
nah not going to Mallala.....got some big job's on at work :(
Tell dad that I'll be coming up and asking for some photos and to let me do it :)
