haha I was on turn 1 at that race too and saw that camaro powerslide turn 1 everytime!
was awesome!
ROFL.......I watched him do that from in the car.....was f#$king awesome....Stubber really knows how to steer that thing!.....was pissing myself laughing in the car at the time and had a good laugh with him later about it!
I got a few more shots, but they arent the best!
What did you think of the handicap race?
How does it work? i.e. a group starts...then another...then another....but how did they work out when to start everyone?
I liked it(but then again what's not to like when you in a GMS R32)....done right all the cars are suppose to come down the straight together on the last lap.
60's cars get 45 seconds(I was a bit lost on this as the Mustang driven by Des Wall was lapping in the 1:50's)
70's cars get 30 seconds
80's cars get 15 seconds
Then the 90's cars go and we have 5 laps to catch everyone....so I would of had to have been doing 1:41's through traffic to catch Des Wall :P
This is close to what I was temped to do at Lakeside to this Walkinshaw.... it mustn't have mirrors. Jetwreck can attest to that. LOL
your right!......there was 2 more hit's from the VL after that........and before the apex on turn 3.....the VL ended up going off at turn 8!
Let's just say he was not playing nice!
Jetwreck..Were you with the Winfield crew???
I have a few more photos from the awesome photographer Scotty of close calls will post them up...The Aussie cars where getting into it...
Love the Peter Jackson Seirra's epic fail tho............ :) Awesome pics!!
I'm gonna give up my left nut this Sunday to get a photo of me sitting in one of the GT-Rs. Jetwreck, you coming down to Mallala?
nah not going to Mallala.....got some big job's on at work :)
@sinful : After the DR30 broke I was working with Dad on the GIO car...I also did the Handycap race in it!
Oh cool...I know Paul and Jose very well!!
Make sure you say Hi to me next time all I will just go up to everyone and ask "Are you Jetwreck???" LOL
nah not going to Mallala.....got some big job's on at work :(
Tell dad that I'll be coming up and asking for some photos and to let me do it :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
