I am starting TAFE full time on Monday and am looking at the possibility of selling my pride and joy. I have had the car since September 2001, and I am the only Australian owner. The car is a pleasure to drive, and is very reliable. It is serviced every 5000km and is garaged every day of the week, as I am lucky enough to walk to work (so it never has to sit in traffic).
The car has been left relatively stock. The paint is the reason I bought the car, and the condition of the paintwork is always complimented.
The Car has
- Immaculate Silver Factory Paint
- 108,000km
- Major service done in Jaunary (yes, it's only done 8,000km since then)..
- Bosch Fuel Pump
- HKS Hyper Exhaust. Front pipe, and high flow cat.
- Autometer Boost Gauge (silver faced) mounted underneath the wiper controls.
- Very smooth gearbox.
- Rego to 04/09/2003*
- Tinted Windows
- R32 GTR rear wing
- Rear pods
- Side skirts from Jetspeed (not fitted)
- Alarmed
- Front, and rear speakers replaced with JBL and Pioneer.
- Pioneer CD player
- Kenwood Amp
- R32 GTR Rear seat
- Repadded front driver seat. Very comfortable
Just looking at offers at this stage.
Would part with it for around $16500. This is a very clean car, in great condition.
*I got my rego papers in the mail the other day. The rego can be renewed to have 12 months on it, or you can pay the rego, and we can take it off the price of the car.
Pics:
http://groups.msn.com/Paul17maher/shoebox.msnw?Page=1
Email:
[email protected]
https://www.sau.com.au/forums/topic/20566-very-tidy-r32-gtst-sydney/
Rear pods are the little bits of body kit behind the rear wheels, like an extension of the side skirts. Im pretty sure they come standard on Type M GTSt.
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
