Boost controller but it's a full inspection as it's a mechanical mod. So means back to stock for me. :( Thanks to some of the guys like ENR34_Luke who's helping me out with rims. SAU FTW.
spotted an identical twin to ryan's 33 parked at the bay last nite. white s2, mesh wheels, low stance, (a lil bit dirty round the exhaust but overall) clean as, but no stickers (and i know you have one on the back window............)
isnt it good to find out you have a twin sometimes :)
hahahaha matt that WAS my car!!! No one has my rims in that offset and size....so no twins bro.
btw, stickers are for chumps.
Edited by Ryanrb25
so ya ditched the adelaide tyrepower sticker from the back window eh? last time i seen ya car it still had that....................so was looking and going "f**k me, im sure thats ryans car"
Spotted a black 33 at Bp St Mary's this afternoon, it had a gtr wing and an sau sticker. Looked nice :D.
Cheers fella, did you have some damage on yours? remember seeing a red 33 as i was leaving
haha yea took it off, i represent myself lol nah it half came off at the lazer wash so i took the whole lot off.
spotted 2 silver r33's last night going down ansac highway on the way back from sau drive in night. one was being a bit silly trying to drag a worked oldschool falcon gt. i just sat back and whatched the tomfoolerie
did he find the unit under the bonnet or your control unit was easily visible
Is it possible to hide all the stuff under the bonnet so the cops cant see it easily?
I need to get one installed soon so i need to know good spots
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
