did he find the unit under the bonnet or your control unit was easily visible
He found the blitz solenoid under the bonnet.
So yep, i'll be driving a suzuki swift with shot brakes, bad steering and about 20% tyres.. but so long as my skyline's out of action that'll keep public safety up. Nice one sapol.
Driving in my little wiked Holden Cruise
Spotted two guys in a silver stock R34 on South Rd.
Wanted to try drag them in my little wiked 4clinder banger haha but then they boosted off lol
spotted a sweet white 33 with very nice kit and rims on cheltenham parade and turned onto torrens rd proudly supporting a SAU sticker in rear quarter window. i boosted past you in my 32 and was followed by a slammed as hell maroon 33 on stockys tryin to keep up.
not overly a fan of the 33's but the white one looked the piece.
saw VANGE last night on anzacs about 11ish i think it was. Looked very confused to see a guy in a falcon waving at you, i was trying to point to the sticker on my rear 1/4 window, you got it eventually lol.
hey that was me mate! your car sounds pretty smick i might say! and you've got a bit of power to i see, nice! oh and i didn't realise why you turned off torrens but when you did i saw that cop and turned onto days rd! hahahaha
Edited by nos man
cheers thanx for that. exhaustis a bit quiet for my liking but it attracts enough cop attention as it is.
the power well its not to bad. always love more but im sellin it so yea. puttin another turb on it soon as im sick of that one and its a lil sick itself, hense the smoke on gear change.
i turned off cause of that cop for sure and then took it easy.
god i hate cops.
saw a white 32 with white impuls and a SAU sticker on rear 1/4 window at TTP on friday night, ABSENT maybe?
3 32's at marion, one stockie looking gun metal with rims, had plates HURRYUP
Another gunmetal one, lowered on stockies still.
And a white 4 door next to it with a badge that said GTR powered. Was 4 stud but had front mount so possible 26 conversion? Also had rims.
Spotted a silver R32. Had black rims crossing the bridge at Port Adelaide from Victoria Rd. We we're both staring at each other to try and see if we recognized one another haha
Actually, I think it was Min_R32
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
