spotted Mitch (DamageInc) on Sir Donald Bradman Drive at around 3:15 today. - yep that was me in the white 34 bro.
on my way back to work from a xmas lunch, almost too many beers lol....
hopefully it wasn't your skyline all smashed up that i saw @ 4pm heading towards Salisbury on main north rd @ pooraka McDonald's
saw charmaine turning onto sherriffs road yesterday. I was in a commodore with no plates/tradeplate, probably didnt see me.
also a black S1 Autech stagea turning onto Perry Barr road at Hallet cove from Brighton rd today around 5.30
spotted "R34GTT" on a road which i have forgotten the name of..........the one that goes past the coca cola factory just outside the city.......got a wave so i waved back........ lol hi terry! haha
i cant even remember where i was 1 hour ago haha ,
did i give you a retarded last minute wave ?
think i remember haha
"i cant even remember where i was 1 hour ago haha ,
think i remember haha"
U sure did hahaha - was classic.....
ahahaha !
gotta love trying to get ya hand out the window when its only down an inch haha !
spotted clean_gtst at the bp on main north and craigmore, had a quick chat with him, clean your damn car dude! ;)
hehehe ... wonder who that was :domokun:
havent the foggiest, had some crazy woman in the passenger seat though.
spotted a silver 33 4 door with 34 GTR wheels on grand junction rd this morning bout 8
was in the truck with electel written down the side heading towards hanson rd
That was me man , but sorry didnt see ya, i had one too many brews last night and was a tad under the weather this morning :domokun:
Edited by IZZMO 33
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
