spotted my car at tailem bend :D
and this across the road at the Shell servo a couple of weeks ago:
Yeah seen lots of those inside holdens. Been doing a lot of leak testing on them.
I've never seen those at the plant.... then again I only usually visit on day shift these days
Yeah we had the GCA guys and the engineers using the outside water test booth. Testing the hard tops and the convertibles. Only plant in the world with a test booth like GMH
hahahaha his famous!
http://www.news.com.au/adelaidenow/
http://www.news.com.au/adelaidenow/gallery...5014156,00.html
lol @ this one... poor guy.
Also spotted a bunch of SAU-ers at AJD.
EDIT: Carl just bet me to posting the beached as ford up lol
spotted HR32 on glen osmond rd tonight,
the white r35 gtr on main north rd, looking as sexy as ever lol
a silver r33 at paddy's market
a white r33 with a boot that didnt look too good on grand junction rd, had black rims
you cought me with a mouth full of chips :P
nice meeting you mate. glad the cars still in the same shape is was when you first saw it being built :w00t:
also saw, andrew, luke and dave there. cheers for the photo of the s13 dave!
Edited by Import S13
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
