Was a SICK day & I really had a ball. Drove my Race GTR for the first time in 2 years & also took my
new R35 out for a few fun laps as well. Good to see the Skylines out numbering the Porsches & Ferraris!
Fun to see a $700,000 Ferrari doing off road work in the paddock as well!!!
Congrats on the laps times Martin - you really know how to boogie.....
Hey John,
What im curious about is which of the GTR's you had more fun in?? Hows the 33 go compared to the 35?
Nope, was a private track day. No spectators are really alowed at these days, as they don't want 1,000,000 people wandering around and getting in the way. You gotta know someone to be invited and go as their 'crew' :)
i was only invited because i complain a lot. :)
Like a little whiny bitch :)
And you got to sit in an R35GTR, then had the gall to complain you didn't get to actually drive in it .... pftt :P
haha yeah the roar of Munro's R33 was beyond belief down the pit straight wall .... but you gotta expect that fron straight pipes out of a 600+ rwkw beast :)
Despite my sore ears you couldn't wipe the smile off my fae :)
dont think ive ever heard anything so unapologetically loud before...
haha, same, was an awesome day.
Edited by scandyflick
Yeah the race GTR is LOUD. The R35 is QUIET. The amazing thing is that is is not much slower.
To answer the question.... on the track the Race car is raw & crazy. nearly 500kg lighter with the
holinger sequential box it is just awesome. Didnt get a lot of laps in due to brake fluid going off
but did pull a few low 17s just getting used to it & it has lots of potential. Cant wait for another go.
The R35 is just amazing. Had a roll on from 90kays with my street GTR behind & the midnight purple
R34 GTR with 480rwkw & he got 1 car length & I slowly pulled him in. Unbelievable. Was shocked.
They are freaks & I havent even touched it yet (go actuators/midpipe/COBB etc)
Does feel heavy on the track though, but did do a few 19s in it.
Keir was doing low 16s !!! in his R35. As I said they are freaks.
So race track - Go R33 (stay off pit wall if you value your eardrums)
Street/hills - Go R35
Making everyone deaf - Go my street R33 on wastegate
Nissans Rock.
Nissans Rock.
hey munro
pls pm me your address so i can mug you for your cars :)
-D
so whats the end result with the 32 bro??? what broke???
so how is the paint on the lancer??? my mate rang me and said you got it done there. thought you would have sold it by now
Got the 32 back today. It was the clutch pedal box, one of the welds snapped off so everything has been strengthened. Price seemed a bit steep but i guess that's what you pay for repairs these days. Also now i got a crook old shaking with the wheel when i drive along. I think its time for a wheel alignment. :down:
The lancers paint is awesome all i had done was a touch up from where a kid split the paint after hitting it. All good now. Havent really had the car out on the streets for anyone to have interest in it really.
Damn....... that's a hard spotting act to compete with!! :P Haven't even seen an R35 in the flesh yet - let alone race one at Mallala!!
Saw a damn nice black Stag at 12pm heading north on Brighton Rd in Glenelg today - custom plates - JBT (or something like that). Anyone's here? Looked tough as.
Edited by 32godzilla
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
