I finally spotted an R35 GTR on the road today. A white one on Park Tce just outside of town. And then later I spotted a GMG one parked on O'Connell St.
There were stacks of other Skylines around but those 2 were memorable. I also saw the pink R33 N1SMO or N15MO or whatever it is.
And a Lamborghini Countach on a hoist and looking like it was missing some items eg wheels, bonnet, doors
funny thing is, my mech has an lp500 countach in the garage, as well as a 700kw gt v8 ute, a 57 tbird, 77 stingray a high performance speed boat with supercharged v8....
-D
Spotted SLY 33, black with black rims, no wing, standard hight by the look of it, sounds pretty stock, but nice. Spotted in the morphett vale area today/all the time. Was about half hour ago.
thats me :happy: where abouts was that? yeah im always out and about
do i have permission to missile my car into that R33 GTS-t going round with GTR badges and plates "33 GTR" ?
seriously every time i see it i wanna drive into the nearest stobie pole and end my life.
yep
anyone rocking a gtr badge on a not gtr needs to be shot
was a really wak 33 at the show today in a display, worst kit ever
-D
Seen ya going past my place, up elizabeth road (u probly dunno where that is but) in m/vale. Recon ive seen your car parked on south road in seaford? Nice looking car mate.
Was it white?
Used to see a white one with GTR badges all over it, but they also had the gts-t on the boot??? :huh::) :) :happy:
spotted dan in the red 35 GTR on belair road around lunchtime, waved but dont think he saw me. Then saw about 20 skylines in town today, few 32 gtrs and a couple 4d 33s and 34s too many to remember lol.
fair few skylines out tonight around the magil,modbury,holden hill area.
spotted a really nice r30? booted it down mctintyre road, also a silver r33 apeared to be mspec was pulled over on st burnards road near magill road. hope all is well.
did the r30 have plates?
http://nissansilvia.com/forums/index.php?showtopic=413101
Was it white?
Used to see a white one with GTR badges all over it, but they also had the gts-t on the boot??? :D:P:yes::blush:
yep he lives round my area (daw parkish), ive seen him for around for a good few years, every time i see it i die a little bit more inside.
yep
-D
nah it's like stock bodied, doesnt even make an effort to make it look like a GTR, just has badges and plates "33GTR" or something to that tune.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
