Maroon 32 possibly gtr, on a car trailer on payneham road 10 minutes ago
I spotted this on OG road, I'm pretty sure it was SNIPER only seen it from the side but it did have gold GT-C's and the car towing it looked to have Lewis engines written on the side.
Also spotted DARE YA this morning on Unley rd and then RBT 025 on the same rd a few hours later. Also a gray 35 GTR on Brighton rd in front of the Holden dealer after work.
Spotted a black 33 with white starcorp inpuls today at the south rd/beach rd/doctors rd intersection, it was at the lights on doctors road. Only saw the front, had standard plates.
Seen (OO Black 33 OO) in regency tafe car park, I was parked opposit you in the white 33. Also tonight spotted two 32 , one was a lime green colour got a wave looked like a track or drift car and the other was a silver 32
spotted what looked like a White R32 with gold drift Teks about to get defected on south rd later tonight.
If your on here, hope u reminded the cop for not wearing his high vis vest when on the road. He can get fined and in shit for it :happy:
Also a silver R8 down my streets work. Been going down there alot recently and doesnt mind giving it abit. :)
Yours the one with the synergy sticker on it??
Spotted and had a chat to a silver s2 RSfour S driver yesterday arvo
Also got tolled my car was "hot" leaving IGA supermarket by some old feller haha
And last night on the way home from hospital spotted "VANGE" turning onto greenhill road. Very nice 33 mate!
Yep I reckon it was sniper looked like it from the plates & yeah was a silver navara with stickers looked like the Lewis ute, i spotted it just on payneham road / O.G. road intersection Looked tough as nails !
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
