well.
69UOM1 proved how hektic he is again today, by STALKING my girlfriend Jess and her friend who were walking, for 2 blocks, doing a U-turn, just so he could pull up on the side of the road next to them, whistle at them, do a burnout, and slide it all the way up the road.
Dude, if you're on here, I only have one thing to say:
You're a F**kwit.
Hope he writes the car off being a douche as always. We wont have to cringe every time we see it, and He'll get what he deserves.
Win win situation the way I see it.
http://adelaide.gumtree.com.au/c-Cars-Vehi...QAdIdZ166299455
:bunny:
saw a yellow 34 coup going down towards junk food corner morphett vale.
had a massive hks sticker down the side with the whole wolf thing onit too plus some other stickers, drift r's and i think ACT plates.
loose the sticers dude and it'll be sweet
Edited by Import S13
lol his selling it and said its only driven on sunday, i see the prick driving it everyday near my area. Always slidding it aswell.
Edited by kb-r33
Spotted Sled last night at Dinner with his wife and kids. >_<
good to see you again Shaun.......& Hostile & Ryan (ISC) & Geoff (EHP) & RBWARE (with wife & daughter).
Also spotted a Patrol truck briefly on Brett West's Mainline rollers getting its exhaust pipe cleared out....wasn't yours was it Matty?
Spotted a silver 33 last night at woodville hotel in bottleshop next to mine, half tint, looked like a home job, revving his engine like i was impressed :)
This morning on way home spotted a black series 1 33 near womens & childrens hospital, looked like it had 350z wheels.
Then a white 33 with drift lip on king william
Grey 32 GTR on corner of west tce and anzac hwy, big defect label, unlucky
Lol just looked at his add, great spelling for starters, $27k for that? Seen many average cars at autosalon, doesn't mean it's a show car lol. 68UOM1 brain cell
well.
You're a F**kwit.
When I was working at sinergy that filthy leb jockey brought his car in there.
Cvnt really is a 'hecktik' sh1tcvnt...
I hope you deleiver to him what is in order or he cops some sort of other bad karma.
Spotted a black 33 yesterday, seen it a fair few times around christies beach area, sounds pretty tough.. Had S series plates.
Also had a silver S15 come past my house the other day and toot at me? Anyone on here.. Always going past up elizabeth road..
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
