Spotted Aaaahhhh33 last night on South Road.
Also spotted 2 bogans talking to me last night at like 3am in Hallett Cove. One said his FPV was running 320psi on his "$60,000 turbo"
What are you? From Queen St Smash?
Then the other told me I should get some 20" rims and roll the guards "like his Datto". What a fail.
those guys sound like the muppets who live up the road from me..lol
spotted white R32 GTR beach rd
wine R33 GTR on south rd not far from o' sulleys beach rd. about 9am
Just saw a porn looking s2 silver stag with what looked like gold vs-xx's and I think a days kit sitting at the lights on south rd crossing regency.
If you heard that loud r33 that was me :blush:
spotted 'ICULKIN' twice within 10 mins yesterday arvo round lunch time... first one was on o'sullivan beach rd, lonsdale... then on aldenhoven road...also in lonsdale.... i was the big fella walking along gawking at your sexy ride :P
thats my mates old plates of his commy :P
Red Stagea with SAU stickers on rear side windows turning at about 2:50pm from right off of Goodwood road - Cross road.
Friendly waves exchanged
White R34 2dr on parked on the side of the road near Springbank road. Custom plates??
Opposite Adelaide oval at approximately 4:30. :P
Opposite Adelaide oval at approximately 4:30. :dry:
This guy in the Ferrari ended coming into my work, (think thats where he was heading when you took the photo ) i think they just bought a new BMW
Spotted a black 4door R31 driving down main north this moring on the way to work. He was reving and swearing in frustration at the lights, swerving between traffic, tailgating, and cutting people off.
Seriously mate, calm down, life is way too short to be stressed! Plus that with all your manovers, I was behind you at every set of lights cursing along in my daily.
Your car sounds pretty tough tho!
sounds like the bloke thinking of buying my 31. his also has rb20 turb
Spotted Mstr34 in Blackwood and went on a short cruise down to Noarlunga... good to meet ya mate :O
haha spotted him at a house - MSTR34, home possibly? in blackwood as i went past this morning on a cruise by myself to kill time, would have tooted, but my horn doesnt work :P
Spotted yellow dayz stag on goodwood at about 3 yesterday Good to seya bro. Also just seen a silver stag boot it over the galipollie (incorrect spelling yeah?) underpass. Looked like a for sale sticker on rear side windows.
Spotted a white 34, possibly MSTR34 again, just before in Blackwood while also going for a random cruise.
Lots of spots today,
Yellow r34 nismo following me down from findon rd to hanson rd
Black r33 Gepps X shooping center
Black r33 parked next to at Radio Rentals Main North rd
Gun metal r33 Target Shopping center Sefton Park.
2 x white r33 south rd heading North near port rd intersection, gave a wave to both.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
