Keep spotting a red 32 in the ikea car park, same park a few days this week, anyone from here? Has stock 32R rims, could be a 4dr too, but cant remember stuff this early in the morning..
Waved to a silver stag and got a wave back. Cant remember where it was. Also saw a red stag about and hour ago behind the airport (also cant remember the road) heading towards anzac highway. Got a wave back from him also. Sorry for the crap memory. If you guys are on here you know who you are. :)
yea no lights, they only turn them on after they have followed you for a bit lol
yeah i thought they had to turn them on as soon as they went over the limit, but they are a law unto them selves
my god! youre right! id almost forgotten. id be lost without kind individuals such as yourself reminding me.
haha gold David, gold. I'd love to meet you in person to see how much of a smart arsed tosser you actually are. But I somehow doubt that you present yourself and carry on anything like you do on this forum. Seeing as you blog every useless thing that happens in your life on here that nobody gives a flying fark about, we'll have lots to chat about. What do you deal? Blackjack? or is it Baccarat?
  • Like 4
  • Nope 3
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
