fairly sure i spotted lucas in 'dare ya' ....minus the plates, on blacks road around 5.20pm
and, i ha had to walk past matty t's bus all day at work...lacks LED's...
spotted some rough but tough 180sx's/200sx's parked at lobethal last night. saw some FAT offset ;)
and at least 2 rolls of gaffa tape and a jumbo pack of zip ties attached to the vehicles
needless to say, i had my 'oh shit' tool box in the back with assorted tools/tape/ties/jumper leads
spotted the gayest thing this arvo!!!!!! two vx commodores, a tidy maloo and a white rex cruising....... by cruising i mean weaving traffic through the hills through mt barker, overtaking on double lines and blind corners, one commodore pulled overtook double lines into a old lady pulling out of a servo. the poor woman froze on the spot and parked in the middle of the road.. mate wish i was that tough.....arms hanging out of the windows flickkin ya ciggy ash over the cars behindya ..... guess the hero was the guy who got to strath and had to pull over and wait for his fully sick mates to catchup.... it really is now wonder that when they show impound yards on the news they normally are full of thrapped commys and fords..
respecta points earned once again
Saw a Toyota Avalon last night come down to a bend on Greenhill Road, slam the brakes on and go sideways into an imbankment, scrape the side of the front bar, down the side to the rear bar, poor bugger, think he saw an 80 sign somewhere and thought that meant 80k's around bends too.. Leaves, small branches and shit went everywhere.. Kinda freaked me out as he could have hit the inbankment then come across and into me, didnt stop so didnt do any wheel or suspension damage, except maybe alignment..
Followed a black 34 GTT last night along Sheoak Road down to Windy Point, had LED tail lights and mad camber on the rear, looked damn hot! Few LED's were not working and flashing when you were braking....
spotted our el-presidente in christine's 34R on the mallala-two wells road this arvo :)
plus luke enr34, dale and jenkies up on the hill whilst watching time attack
and "marty block" :laugh: oh lordy, what a sense of humor :laugh:
spotted the biggest f**k wits just 5 minutes ago going up cross road in a Silver R34 GT.
one of the f**k wits was hanging out the window and the other was flooring it in about 2nd with a 2 bit filthy jin tit Non turbo with a fail fart cannon
then turning up the free way the f**k wit drops 1st at the lights while this other dick bag is hanging out the window...
dont worry sweethearts your best mates in blue have your number plates now so enjoy those last few hours of being a sick flamin mongrel because reality is about to hit.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
